22
How to dynamically enable and disable IPv6 on an interface so that it gets link local address when enabled? I have tried:
sysctl net.ipv6.conf.all.disable_ipv6=1 to disable IPv6
and
sysctl net.ipv6.conf.all.disable_ipv6=0 to enable IPv6.
Are there any other ways?
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
LxBgnr
  • 221
To disable IPv6
$ su -
# nano /etc/sysctl.conf
and add these lines to sysctl.conf file
#disable ipv6
net.ipv6.conf.all.disable_ipv6 = 1
net.ipv6.conf.default.disable_ipv6 = 1
net.ipv6.conf.lo.disable_ipv6 = 1
net.ipv6.conf.eth0.disable_ipv6 = 1
Save sysctl.conf file with new config and run the following command to enable the new settings:
# sysctl -p
Check your system again
$ cat /proc/sys/net/ipv6/conf/all/disable_ipv6
Now you should see “1″ means IPv6 has been disabled on your system.
From http://namhuy.net/1419/disable-ipv6-ubuntu-linux-mint.html
I think your approach is valid as it is. You could use the per-interface settings if you don't want to change settings for every interface, e.g. net.ipv6.conf.eth0.disable_ipv6
I wouldn't recommend touching anything else.
freddyb
  • 1,359
To turn off IPv6 in Ubuntu 11.04
Firstly, On or off, check it out
$ ifconfig -a
eth0      Link encap:Ethernet  HWaddr
          inet addr:  Bcast:  Mask:
          **inet6** addr: fe80::210:f3ff:fe21:722a/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:982 errors:0 dropped:0 overruns:0 frame:0
          TX packets:943 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:800461 (800.4 KB)  TX bytes:144524 (144.5 KB)
          Interrupt:20 Memory:f7d00000-f7d20000
eth1      Link encap:Ethernet  HWaddr
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          Interrupt:16 Memory:f7c00000-f7c20000
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          **inet6** addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:20 errors:0 dropped:0 overruns:0 frame:0
          TX packets:20 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:1200 (1.2 KB)  TX bytes:1200 (1.2 KB)
Secondly, Turn off, i modified the line as following and patched the grub
$ grep ipv6 /etc/default/grub
GRUB_CMDLINE_LINUX_DEFAULT="ipv6.disable=1 quiet splash"
$ update-grub
Generating grub.cfg ...
Found linux image: /boot/vmlinuz-2.6.38-11-generic-pae
Found initrd image: /boot/initrd.img-2.6.38-11-generic-pae
Found memtest86+ image: /boot/memtest86+.bin
done
fossfreedom
  • 174,526
