27
I disabled IPv6 on an Ubuntu box which has ssh and rsync running. But both of these are still listening on an IPv6 address. How should I fix this?
root@box.com:~# sysctl net.ipv6.conf.all.disable_ipv6
net.ipv6.conf.all.disable_ipv6 = 1
root@box.com:~# sysctl net.ipv6.conf.default.disable_ipv6
net.ipv6.conf.default.disable_ipv6 = 1
root@box.com:~# sysctl net.ipv6.conf.lo.disable_ipv6
net.ipv6.conf.lo.disable_ipv6 = 1
And
root@box.com:~# ss -lnp6
State      Recv-Q Send-Q        Local Address:Port    Peer Address:Port
LISTEN     0      128            :::22                 :::*      users:(("sshd",1505,4))
LISTEN     0      5              :::873                :::*      users:(("rsync",3423,5))
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
ACC
  • 389
5 Answers5
40
This worked for me:
Add these lines to the bottom of sysctl.conf
Then run sudo sysctl -p or reboot
source: http://www.noobslab.com/2012/05/disable-ipv6-if-your-internet-is.html
This of course won't stop bind from blindly trying to use ipv6 though, so you also need to alter /etc/default/bind9 like so:
# run resolvconf?
RESOLVCONF=yes
# startup options for the server
OPTIONS="-4 -u bind"
source: http://blog.evilcoder.net/disable-ipv6-on-bind9-linux/#sthash.U95y4s6U.dpuf
Jos
  • 30,529
  • 89
  • 96
boatcoder
  • 599
22
To check if IPv6 is enabled or disabled, from a terminal window:
$ cat /proc/sys/net/ipv6/conf/all/disable_ipv6
0 means it’s enabled and 1 is disabled.
To disable IPv6
$ sudo su -
# nano /etc/sysctl.conf
and add these lines to sysctl.conf file
#disable ipv6
Save sysctl.conf file with new config, then reboot your system
# reboot
Check your system again
Now you should see “1″ means IPv6 has been disabled on your system.
From http://namhuy.net/1419/disable-ipv6-ubuntu-linux-mint.html
  1. Open a terminal and type the following command (if you don't use Gedit, replace it with your text editor such as Kate, etc).
    sudo gedit /etc/default/grub
  2. And search for this:
    GRUB_CMDLINE_LINUX
    Modify it so it looks like this:
    GRUB_CMDLINE_LINUX="ipv6.disable=1"
  3. Now, let's update the GRUB:
    sudo update-grub2
    Or if you don't use GRUB 2, do:
    sudo update-grub
  4. And finally, restart your system.
Eric Carvalho
  • 55,453
nicoX
  • 1,160
Disable listening on ipv6 addresses for some services.
sshd /etc/default/ssh
# Options to pass to sshd
SSHD_OPTS="-4"
avahi-daemon /etc/avahi/avahi-daemon.conf
[server]
use-ipv4=yes
use-ipv6=no
java /etc/java-7-openjdk/net.properties
http.nonProxyHosts=localhost|127.*
ftp.nonProxyHosts=localhost|127.*
Then restart services
service restart sshd
service restart avahi-daemon
service restart tomcat7
In my case tomcat was using java with ipv6. May differ for you.
To just turn of IPv6 on your computer, why you ever wanted to do that, is easy. Just add one line to a configuration file. Yes, you have to be root to create the file.
$ cat <<EOF >/etc/modprobe.d/blacklist-ipv6.conf
# To turn off IPv6, though you don't need too.
# But anyways.
blacklist ipv6
# eof
EOF
Just reboot or try:
$ sudo rmmod ipv6
Anders
  • 1,615
