10
I'm trying to install JDK7 on ubuntu 12.4.
In the first try, the power has gone and the laptop shutdown in the middle of downloading JDK7 using terminal as I was using the next terminal commands
sudo add-apt-repository ppa:webupd8team/java
sudo apt-get update
sudo apt-get install oracle-java7-installer
when the power returned and I tried to install JDK7 again there was a problem with the lock but I fixed it using the following commands after restarting the machine
sudo apt-get install whatever
after that I tried installing again using the three commands above, the first was done with no errors and the second too,
but the third command downloaded the package successfully but an error appeared
Download done.
Removing outdated cached downloads...
sha256sum mismatch jdk-7u51-linux-i586.tar.gz
Oracle JDK 7 is NOT installed.
dpkg: error processing oracle-java7-installer (--configure):
 subprocess installed post-installation script returned error exit status 1
I searched for solutions for this error and found some, tried the following instructions
sudo rm /var/lib/dpkg/info/oracle-java7-installer*
sudo apt-get purge oracle-java7-installer*
sudo rm /etc/apt/sources.list.d/*java*
sudo apt-get update
sudo apt-get update
tried again but the same "Oracle JDK7 is NOT installed" error appeared.
tried sudo apt-get -f install
salahuddin@salahuddin:~$ sudo apt-get -f install
[sudo] password for salahuddin:
Reading package lists... Done
Building dependency tree
The following package was automatically installed and is no longer required:
  thunderbird-globalmenu
Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 259 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up oracle-java7-installer (7u51-0~webupd8~1) ...
Downloading Oracle Java 7...
--2014-02-03 16:28:51--  http://download.oracle.com/otn-pub/java/jdk/7u51-b13/jdk-7u51-linux-i586.tar.gz
Resolving download.oracle.com (download.oracle.com)... 41.128.128.35, 41.128.128.40
Connecting to download.oracle.com (download.oracle.com)|41.128.128.35|:80... connected.
HTTP request sent, awaiting response... 302 Moved Temporarily
Location: https://edelivery.oracle.com/otn-pub/java/jdk/7u51-b13/jdk-7u51-linux-i586.tar.gz [following]
--2014-02-03 16:28:51--  https://edelivery.oracle.com/otn-pub/java/jdk/7u51-b13/jdk-7u51-linux-i586.tar.gz
Resolving edelivery.oracle.com (edelivery.oracle.com)... 23.48.230.140
Connecting to edelivery.oracle.com (edelivery.oracle.com)|23.48.230.140|:443... connected.
Location: http://download.oracle.com/otn-pub/java/jdk/7u51-b13/jdk-7u51-linux-i586.tar.gz?AuthParam=1391437853_a122991b0aaf032ed8c2812472d1c92c [following]
--2014-02-03 16:28:53--  http://download.oracle.com/otn-pub/java/jdk/7u51-b13/jdk-7u51-linux-i586.tar.gz?AuthParam=1391437853_a122991b0aaf032ed8c2812472d1c92c
HTTP request sent, awaiting response... 416 Requested Range Not Satisfiable
    The file is already fully retrieved; nothing to do.
Download done.
Don't know how to fix it
please help
thanks in advance
Salahuddin
  • 4,911
Run the below commands on terminal,
sudo dpkg -P oracle-java7-installer
Avinash Raj
  • 80,446
I have another potential workaround for this, but it requires manual intervention. The reason this has broken is because Oracle wants you to accept an OTN license. Here is workaround:
Go to Oracle Java7 JDK download site (I found it at Here). Agree to the OTN agreement, then find the file named "jdk-7u(whateverupdateislatest)-linux-x64.tar.gz"
sudo mv jdk-7u67-linux-x64.tar.gz /var/cache/oracle-jdk7-installer/
Ashu_FalcoN
  • 2,118
Jim
  • 51
I think that your download is corrupted . you have to remove the corrupted package first by code :
Clean your apt :
sudo apt clean
Remove and reimport the ropsitory :
sudo add-apt-repository --remove ppa:webupd8team/java
sudo apt-get update
sudo apt-add-repository ppa:webupd8team/java
sudo apt-get update
Install your package again :
Enjoy it bro ! if the problem hasn't solved try using VPN . Maybe there is a filtering between you and the oracle website
Check the file /var/cache/oracle-jdk7-installer/jdk-7u51-linux-*.tar.gz
If it is small (~5000 bytes) - then it contains text telling you to accept the OTN license.
If you can, switch to oracle-java8-installer
See http://tiemensfamily.com/TimOnCS/2014/03/15/oracle-adds-license-to-java7-installer-fails
