I'm trying to install Heroku locally into my Ubuntu 14.04 LTS.
But I'm getting this error:
The following NEW packages will be installed:
heroku
0 upgraded, 1 newly installed, 0 to remove and 198 not upgraded.
1 not fully installed or removed.
Need to get 14,6 MB of archives.
After this operation, 0 B of additional disk space will be used.
Fetched 14,6 MB in 3s (4.497 kB/s)
Selecting previously unselected package heroku.
(Reading database ... 333239 files and directories currently installed.)
Preparing to unpack .../heroku_5.6.8-1_amd64.deb ...
Unpacking heroku (5.6.8-1) ...
Setting up oracle-java8-installer (8u92+8u91arm-2~really8u91~webupd8~0) ...
Installing from local file /var/cache/oracle-jdk8-installer/jdk-8u91-linux-x64.tar.gz
Removing outdated cached downloads...
mv: cannot move ‘jdk1.8.0_91’ to ‘java-8-oracle/jdk1.8.0_91’: Directory not empty
dpkg: error processing package oracle-java8-installer (--configure):
subprocess installed post-installation script returned error exit status 1
Setting up heroku (5.6.8-1) ...
Anyone encountered this problem? And how to fix it? For the moment I was thinking to change the owner and the group for these two directories, but I don't know the implications.
Thank you for any suggestions!
LE
I forgot to mention the structure of these two directories:
6952928 drwxr-xr-x 9 uucp 143 4096 iul 22 19:41 java-8-oracle
6832129 drwxr-xr-x 8 uucp 143 4096 apr 1 2016 jdk1.8.0_91
which looks strange to me. Especially that uucp 143. If you need me to provide more info, please ask, as I'm not so advanced in Linux (or such).
Again, thanks!
LE2:
After following @Zanna 's idea, I renamed those two directories, and I ran the installer again. Unsuccessfull, as I get the following error:
heroku is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 198 not upgraded.
Do you want to continue? [Y/n] Y
install: cannot stat ‘javaws-wrapper.sh’: No such file or directory
LE3
Yes, I'm using a ppa. I tried these steps to purge the package: I installed ppa-purge, then I ran the second command to remove it. I got this error:
# First I installed ppa-purge, and at the end, I got the same error: E: Sub-process /usr/bin/dpkg returned an error code (1)
sudo apt-get install ppa-purge
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
aptitude aptitude-common libboost-iostreams1.54.0 libcwidget3 libept1.4.12
Suggested packages:
aptitude-doc-en aptitude-doc tasksel debtags libcwidget-dev
ppa-purge
0 upgraded, 6 newly installed, 0 to remove and 197 not upgraded.
Need to get 2.555 kB of archives.
After this operation, 10,7 MB of additional disk space will be used.
Get:1 http://ro.archive.ubuntu.com/ubuntu/ trusty-updates/main libboost-iostreams1.54.0 amd64 1.54.0-4ubuntu3.1 [29,0 kB]
Get:2 http://ro.archive.ubuntu.com/ubuntu/ trusty/main libept1.4.12 amd64 1.0.12 [142 kB]
Get:3 http://ro.archive.ubuntu.com/ubuntu/ trusty/main aptitude-common all 0.6.8.2-1ubuntu4 [700 kB]
Get:4 http://ro.archive.ubuntu.com/ubuntu/ trusty/main libcwidget3 amd64 0.5.16-3.5ubuntu1 [307 kB]
Get:5 http://ro.archive.ubuntu.com/ubuntu/ trusty/main aptitude amd64 0.6.8.2-1ubuntu4 [1.371 kB]
Get:6 http://ro.archive.ubuntu.com/ubuntu/ trusty/universe ppa-purge all 0.2.8+bzr57 [5.704 B]
Fetched 2.555 kB in 3s (670 kB/s)
Selecting previously unselected package libboost-iostreams1.54.0:amd64.
Preparing to unpack .../libboost-iostreams1.54.0_1.54.0-4ubuntu3.1_amd64.deb ...
Unpacking libboost-iostreams1.54.0:amd64 (1.54.0-4ubuntu3.1) ...
Selecting previously unselected package libept1.4.12:amd64.
Preparing to unpack .../libept1.4.12_1.0.12_amd64.deb ...
Unpacking libept1.4.12:amd64 (1.0.12) ...
Selecting previously unselected package aptitude-common.
Preparing to unpack .../aptitude-common_0.6.8.2-1ubuntu4_all.deb ...
Unpacking aptitude-common (0.6.8.2-1ubuntu4) ...
Selecting previously unselected package libcwidget3.
Preparing to unpack .../libcwidget3_0.5.16-3.5ubuntu1_amd64.deb ...
Unpacking libcwidget3 (0.5.16-3.5ubuntu1) ...
Selecting previously unselected package aptitude.
Preparing to unpack .../aptitude_0.6.8.2-1ubuntu4_amd64.deb ...
Unpacking aptitude (0.6.8.2-1ubuntu4) ...
Selecting previously unselected package ppa-purge.
Preparing to unpack .../ppa-purge_0.2.8+bzr57_all.deb ...
Unpacking ppa-purge (0.2.8+bzr57) ...
Processing triggers for man-db (2.6.7.1-1ubuntu1) ...
Setting up libboost-iostreams1.54.0:amd64 (1.54.0-4ubuntu3.1) ...
Setting up libept1.4.12:amd64 (1.0.12) ...
Setting up aptitude-common (0.6.8.2-1ubuntu4) ...
Setting up libcwidget3 (0.5.16-3.5ubuntu1) ...
Setting up aptitude (0.6.8.2-1ubuntu4) ...
update-alternatives: using /usr/bin/aptitude-curses to provide /usr/bin/aptitude (aptitude) in auto mode
Setting up ppa-purge (0.2.8+bzr57) ...
Processing triggers for libc-bin (2.19-0ubuntu6.9) ...
# Here I tried to purge the package
sudo ppa-purge ppa:webupd8team/java
Updating packages lists
PPA to be removed: webupd8team java
Warning: Could not find package list for PPA: webupd8team java
And now I can't understand why this warning, as both directories are in place. Additionaly, I got this error window too.
