This message appears:
Jan 31 19:18:38.562 [notice] Initialized libevent version 2.0.21-stable using method epoll (with changelist). Good.
Jan 31 19:18:38.562 [notice] Opening Socks listener on 127.0.0.1:9050
Jan 31 19:18:38.562 [warn] Could not bind to 127.0.0.1:9050: Address already in use. Is Tor already running?
Jan 31 19:18:38.562 [warn] Failed to parse/validate config: Failed to bind one of the listener ports.
HELP! How do I open Tor?
Rinzwind
  • 309,379
Kill all "tor" processes :
sudo killall tor
Then start tor again, and finally, restart privoxy and polipo :
sudo /etc/init.d/privoxy force-reload && /etc/init.d/polipo restart
You should now be able to connect.
Apparently, this problem happens when you have either :
1) Multiple version of Tor (then keep only one)
2) Tor and Vidalia running together
For the n°2, Tor was probably installed before Vidalia, and the automatically starts with the computer. If you would like that tor does not run automatically at startup, run the following command :
sudo gedit /etc/default/tor
and change the "yes" to "no" in the following section of this file :
RUN_DAEMON="yes"
For further informations, read :
MrVaykadji
  • 5,965
