I get these errors trying to run tor with vidalia
Apr 19 21:55:15.371 [Notice] Tor v0.2.1.30. This is experimental software. Do not rely on it for strong anonymity. (Running on Linux i686)
Apr 19 21:55:15.372 [Notice] Initialized libevent version 1.4.13-stable using method epoll. Good.
Apr 19 21:55:15.373 [Notice] Opening Socks listener on 127.0.0.1:9050
Apr 19 21:55:15.373 [Warning] Could not bind to 127.0.0.1:9050: Address already in use. Is Tor already running?
Apr 19 21:55:15.373 [Warning] Failed to parse/validate config: Failed to bind one of the listener ports.
Apr 19 21:55:15.373 [Error] Reading config failed--see warnings above.
I don't think tor is running. Here is a nmap scan of my localhost
Starting Nmap 5.21 ( http://nmap.org ) at 2011-04-19 21:59 CEST
Nmap scan report for localhost (127.0.0.1)
Host is up (0.0000050s latency).
Hostname localhost resolves to 2 IPs. Only scanned 127.0.0.1
rDNS record for 127.0.0.1: localhost.localdomain
Not shown: 989 closed ports
PORT STATE SERVICE
22/tcp open ssh
53/tcp open domain
80/tcp open http
139/tcp open netbios-ssn
445/tcp open microsoft-ds
631/tcp open ipp
3128/tcp open squid-http
3306/tcp open mysql
9000/tcp open cslistener
9050/tcp open tor-socks
10000/tcp open snet-sensor-mgmt
I see tor-socks is running here, probably be the cause of the problem. How do I stop this from starting up? I want to use vidalia so I can monitor whats going on.
