This is not question about how Linux works or something similar. I just want ask if is there some similar application like Xilisoft Video Converter and Sony Vegas Pro 10. Because I need an application, where I can edit a video, add subtitles, convert and more. And something like Vegas Pro for editing videos (like cutting, color edits, add music and other). Thanks.
Edit: + software like notepad++
Avidemux is a free video editor designed for simple cutting, filtering and encoding tasks. It supports many file types, including AVI, DVD compatible MPEG files, MP4 and ASF, using a variety of codecs.Avidemux
To install you can also click Avidemux Install comixcursors-lefthanded.
Video Editing program OpenShot Features include: Support for many video, audio, and image formats (based on FFmpeg), Gnome integration (drag and drop support), and Multiple tracks.OpenShot
To install you can also click OpenShot Install comixcursors-lefthanded.
Lightworks is an editing powerhouse, delivering unparalleled speed and flexibility, fully integrated with the other members of the Complete Collaboration family.Lightworks
As far as Notepad++, you can use sCiTE. SciTE is available in apt repository of Ubuntu. To install it just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command(s) below:
sudo apt-get install scite
To convert Video, take a look at:
HandBrake is an open-source, multithreaded video transcoder- it converts digital media from one format to another, compressing the files in the process.HandBrake
Mitch
  • 109,787
Alternative 1 to Xilisoft Video Converter: I always do my conversion on the command line with ffmpeg as it's fast and effective. There is a bit of a learning curve, however there are numerous front ends available for ease of use several of which are mentioned here: https://github.com/amiaopensource/ffmpeg-amia-wiki/wiki/3)-Graphical-User-Interface-Applications-using-FFmpeg
Alternative 2 Another powerful video editor that is an alternative to Sony Vegas Pro (open source) is cinelerra.
Alternative 3 There are several good alternatives for programming editors like notepad++. Ive used both gedit and scite (both of which are available via the software center) and found them both to be quite satisfactory.
Note: To install SciTE you'll need to enable the universe repository first.
Elder Geek
  • 36,752
