I'm having a pretty serious problem right now that I hope someone can help me with. I can't seem to load Windows 7. I just started and set up a dual boot of Windows 7 and Ubuntu. My windows was working fine before installing Ubuntu. However now whenever I select the Windows loader option in the Grub menu it won't work. It will appear like its starting to load but then after a few minutes it will take me to the startup repair screen (I think that's what its called). After several minutes of waiting it says that it can't repair it and suggests using the system repair disc...which I don't have.
I've have searched and tried several different "solutions" to no success. Is there a way I can create a System Repair disc using a USB drive from Ubuntu?? Doesn't seem possible to me.
Or could it be that Grub isn't loading Windows 7 correctly? Is there anyway I can just bypass Grub? Or not use it at all. Maybe what I'm trying to ask is can I boot Windows 7 directly from the BIOS menu or something?
I wish I never had even considered dual booting and should have just stuck to a virtual machine.
Can anyone help??
Thomas Ward
  • 78,878
As a temporary solution, you can always select the Windows entry, hit e, then find /dev/sdb1 and change it to /dev/sdb2. If you want the modification to become permanent, look for example at How do I change the GRUB boot order? or, better, at Grub points to recovery partition instead of install partition.
landroni
  • 6,011
