12
I was wondering, I like the fullscreen mode (host + f by default), but this is unfortunately not very helpful with a 3200x1800 resolution screen (15 inches). The scaling mode (host + C) is better, but not quite the same. what I want is something like fullscreen scaling, where you can set a maximum resolution, beyond that it scales to fit the screen. (at least I think I want something like this.)
If I had to pick a static resolution then that's ok too. (say i'd like to pick 1920x1080 for my 3200x1800 display), and then have this resolution stretched / scaled to fullscreen coverage. But how would I go about this?
I hear there's the same kind of issue for others with retina displays where the dpi is so high that all of Ubuntu's icons / buttons and UI in general becomes too small for comfort. I feel that until Ubuntu officially supports high DPI screens, then scaling it from a virtualbox image must be achievable right?
Last point... this might be an issue with the vbox additions driver auto adjusting the size of the ubuntu window to match that of the host...
I've tried Oracle VM VirtualBox Manager -> File -> Preferences -> Display -> Maximum Guest Screen Size. Which seemed like it was exactly what I wanted, but it did not do anything.
TL;DR: High DPI screen on host, ubuntu guest tries to match this = tiny UI & icons.
Any help would be much appreciated! (the end result is to just want to use ubuntu on a high DPI screen, the path taken does not matter as much. However it seems like I would have most success through virtualbox here)
Maythux
  • 87,123
Finally found a working solution.
Vitualbox -> (select guest) -> Settings -> Display -> Scale Factor
Frankie
  • 241
In Ubuntu 17.10 in VirtualBox. set hiDPI, and scale to 100% in VirtualBox settings. Then open Ubuntu Settings Devices/Displays, Make you window big and you will see a new Gnome setting called scale. Set to 200% and Ubuntu will take full advantage of every pixel in high DPI screen like a mac retina.
See article at: https://teklern.blogspot.com/2017/10/installing-ubuntu-17.html
Ok, so my temporary solution (until Ubuntu supports high DPI i guess...) was to just go down in resolution on my host system (windows), to half the max resolution (1920x1080).
I don't really want to mark this as solved, since it kinda bypasses the problem in an undesirable manner. (this is just what I'm content with doing.)
