I installed Ubuntu 12.04LTS without turning off Fast Startup in Windows 8.1 as I was unaware that this needed to be done. I've installed Ubuntu many times before, but this was my first time with windows 8.1, and unfortunately I didn't look up anything before I did it. I resized the partition and installed Ubuntu successfully and upon reboot, it went directly to Ubuntu without grub showing up. Is there anything I can do as the windows partition is my primary one and there is software that I need access to on it.
Braiam
  • 69,112
Sam G
The answers here may help you. Using boot-repair from a live CD/USB drive is probably the best option because it's a utility designed to fix these kinds of problems. Otherwise, you can try reinstalling grub yourself.
Cerran
  • 390
-1
Press shift to open GRUB menu,and then go to windows 8.
