So I followed the instructions here. However, when I went to Virtualbox and told it to use the file I got the error
Failed to open the hard disk file /home/parth/Win7.vmdk.
Permission problem accessing the file for the medium '/home/parth/Win7.vmdk' (VERR_ACCESS_DENIED).
Result Code: VBOX_E_FILE_ERROR (0x80BB0004)
Component: Medium
Interface: IMedium {05f2bbb6-a3a6-4fb9-9b49-6d0dda7142ac}
Callee: IVirtualBox {fafa4e17-1ee2-4905-a10e-fe7c18bf5554}
Callee RC: VBOX_E_OBJECT_NOT_FOUND (0x80BB0001)
The VirtualBox user should be the owner of .vmdk file and have read & write permissions for both .vmdk and the device it refers to (like /dev/sda). Everything in /dev/ is owned by root, so you have two options:
  1. Run VirtualBox as root. I wouldn't suggest it because such a huge application as VirtualBox potentially have bugs that are capable to crash your system being rooted.
  2. Grant your user the permissions for the .vmdk file and the /dev/sdX device:
    a. Make sure .vmdk is somewhere in your home directory
    b. Make sure that your user is the owner of .vmdk and have read and write permissions for it (right click -> Properties -> Permissions)
    c. Grant your user the permissions for the device:
    sudo chmod 666 /dev/sdX
    (place the required device instead of /dev/sdX)
