So I have a Lenovo u310 with Ubuntu 13.10 on it and whenever I try to disable my touchpad with the special button on my F6 key, it does nothing.
All the other special keys work, like plane mode and refresh page but only the touchpad button is not working.
What might be wrong with it?
inimene
  • 2,236
It does not work for me too(Ubuntu 13.10 Sony Vaio).
But I use following command(with shortcut key)
First determine the device id
xinput list
Then disable it, (this command as shortcut key action)
xinput set-prop 15 "Device Enabled" 0
Replace 15 with your device id.
SOURCE : https://help.ubuntu.com/community/SynapticsTouchpad
Seth
  • 59,332
This does not answer your question about non working key, but it will help in case you want to use another key instead.
  • Another way using Gnome Settings, Which I think it's better and simple as it will well integrated with desktop (Indicators...), the toggle script:
    if [ `gsettings get org.gnome.settings-daemon.peripherals.touchpad touchpad-enabled` == "true" ]; then gsettings set org.gnome.settings-daemon.peripherals.touchpad touchpad-enabled false ; else gsettings set org.gnome.settings-daemon.peripherals.touchpad touchpad-enabled true ; fi
    Query status:
    Disable:
    Enable:
  • Using xinput:
    if [ `xinput list-props 12 | awk '/Device Enabled/ { print $4 }'` -eq 1 ]; then xinput set-prop 12 "Device Enabled" 0 ; else xinput set-prop 12 "Device Enabled" 1 ; fi
    12 is the id you got from xinput list, but there a drawback here using predefined id. For example, If a new USB mouse attached/unplugged before boot, touchpad could get deferent id. (It happens to me with USB mouse, my touch pad damaged)
  • Using xinput and device name instead of id:
    export touchpad_id=`xinput list | awk 'gsub(".*AlpsPS/2 ALPS DualPoint TouchPad[ \t]*id=*","") { print $1 }'` ; if [ `xinput list-props $touchpad_id | awk '/Device Enabled/ { print $4 }'` -eq 1 ]; then xinput set-prop $touchpad_id "Device Enabled" 0 ; else xinput set-prop $touchpad_id "Device Enabled" 1 ; fi
    My touchpad name is AlpsPS/2 ALPS DualPoint TouchPad got it from xinput list, replace it with your device name.
    Get device id by name AlpsPS/2 ALPS DualPoint TouchPad and store it in touchpad_id:
    Query status:
    Disable:
    Enable:
user.dz
  • 49,176
Special touchpad key doesn't work on my Lenovo Ideapad 320 either (Ubuntu 16.04). I installed Touchpad Indicator and configured it to turn off touchpad automatically when mouse is plugged in. The app started doing its job after I changed switch method to Xinput in its settings.
Carter
  • 322
-1
I think this site will answer your question. I do not own any lenovo to answer it SITE http://mydevelopedworld.wordpress.com/2013/11/30/how-to-configure-new-lenovo-x240-touchpad-on-ubuntu-13-10/
John
