I just Install Xampp But maybe somewhere i Missed It Because I can't Load Any Xampp GUI. Also The Browsers Is Not Working Local host URL.
Thank you
I believe that you want to add a GUI xampp control panel. To add a GUI xampp control panel see below.
Just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command(s) below:
sudo gedit ~/.local/share/applications/xampp-control-panel.desktop
When the text editor opens simply paste the following, close and save.
[Desktop Entry]
Comment=Start and Stop XAMPP
Name=XAMPP Control Panel
Exec=sudo -i python /opt/lampp/share/xampp-control-panel/xampp-control-panel.py
Icon=/usr/share/icons/Humanity/devices/24/network-wired.svg
Encoding=UTF-8
Terminal=false
Type=Application
If you have a problem with executing the program, install gksu, and in the forth line, replace sudo -i with gksudo. Below is how to install gksu if not installed, since it has been removed from 13.04.
sudo apt-get install gksu
Look for xampp control panel in dash
I found this article very effective on few systems and it is very simple too :
Xampp has a small python script that creates the GUI we need for controlling the Server
sudo /opt/lampp/share/xampp-control-panel/xampp-control-panel.py
By running the above command, you can see the following small application
you will need the python-glade package to run the above command. If you donot have it , install python-glade use the following command
sudo apt-get install python-glade2
let us create a desktop shortcut for this
[Desktop Entry]
Encoding=UTF-8
Name=Xampp Control Panel
Comment=Start or Stop XAMPP
Exec=gksudo python /opt/lampp/share/xampp-control-panel/xampp-control-panel.py
Icon=/opt/lampp/htdocs/favicon.ico
Categories=Application;Development;Web
Version=1.0
Type=Application
Terminal=0
Create a new file named xampp.desktop place the above contents in it and save it. Change the file permissions so that it can execute.
sudo chmod +x xampp.desktop
double-click that file, Xampp control panel will open…
xampp GUI ubuntu 14.04https://bhargavg.wordpress.com/2011/12/18/xampp-control-panel-gui-in-ubuntu/
