What are the easy and possible ways to upgrade the operating system from 12.04 to 13.04? Are there any option except booting the system with 13.04?
Asked
Active
Viewed 49 times
The easiest way to upgrade (IMO) is using the terminal, you do it by running the command do-release-upgrade.
Optionally if you don't feel comfortable using the terminal you could use the Update Manager, to use it press Alt+F2 and type in update-manager into the command box. Update Manager should open up and tell you: New distribution release 'XX.XX' is available. Click Upgrade and follow the on-screen instructions.
I would also recommend you read this brief guide and backup your installation.
