I was given a free 1GB USB at an event a few months ago - however, when I plug it in to my Ubuntu laptop, the USB shows up as two drives (/dev/sdb and /dev/sdc). I have checked it isn't just partitions - it isn't, since GParted also shows the USB as two drives.
Is it possible to merge the two drives using fdisk or GParted?
The USB was free, so I really don't care if the thing ends up broken. I just want to experiment and see if it is possible to merge the two drives and have a working 1 GB USB.:)
lsusb output:
Bus 002 Device 006: ID 058f:6387 Alcor Micro Corp. Transcend JetFlash Flash Drive
Output of 'sudo fdisk -l'
(precise)kida@localhost:~$ sudo fdisk -l
WARNING: GPT (GUID Partition Table) detected on '/dev/sda'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sda: 320.1 GB, 320072933376 bytes 256 heads, 63 sectors/track, 38761 cylinders, total 625142448 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk identifier: 0x00000000
Device Boot Start End Blocks Id System /dev/sda1 1 625142447 312571223+ ee GPT Partition 1 does not start on physical sector boundary. Note: sector size is 4096 (not 512)
Disk /dev/mapper/vboot: 1090 MB, 1090519040 bytes 255 heads, 63 sectors/track, 16 cylinders, total 266240 sectors Units = sectors of 1 * 4096 = 4096 bytes Sector size (logical/physical): 4096 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk identifier: 0x00000000
Disk /dev/mapper/vboot doesn't contain a valid partition table Note: sector size is 4096 (not 512)
Disk /dev/mapper/vroot: 1073 MB, 1073741824 bytes 255 heads, 63 sectors/track, 16 cylinders, total 262144 sectors Units = sectors of 1 * 4096 = 4096 bytes Sector size (logical/physical): 4096 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk identifier: 0x00000000
Disk /dev/mapper/vroot doesn't contain a valid partition table
Disk /dev/mapper/encstateful: 94.6 GB, 94571528192 bytes 255 heads, 63 sectors/track, 11497 cylinders, total 184710016 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0x00000000
Disk /dev/mapper/encstateful doesn't contain a valid partition table
Disk /dev/sdb: 1021 MB, 1021575168 bytes 23 heads, 54 sectors/track, 1606 cylinders, total 1995264 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0x56e57c2b
Device Boot Start End Blocks Id System /dev/sdb1 496 1995263 997384 6 FAT16
Disk /dev/sdc: 7 MB, 7077888 bytes 256 heads, 32 sectors/track, 1 cylinders, total 13824 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0x00000000
Device Boot Start End Blocks Id System /dev/sdc1 64 13823 6880 1 FAT12
Nicolas Raoul
  • 11,921
You just need to remove a partition. You can use GPART for this.
Here is a guide to help you with that, https://askubuntu.com/questions/824880/how-to-remove-a-partition-on-a-hard-disk#:~:text=If%20you%20right%2Dclick%20on,the%20partition%20as%20you%20wish.
Logan
  • 482
Suggest you use Gparted to delete the FAT12 and FAT16 partitions and then create one FAT32 partition. Pick your USB device from the spin box at upper right http://www.zimagez.com/zimage/screenshot-01262014-025522pm.php then delete the old partitions http://www.zimagez.com/zimage/screenshot-01262014-025931pm.php by right-clicking on each partition and selecting Delete. Then reformat it as the current preferred FAT32 partition type for maximum utility.
K7AAY
  • 17,705
