Ok so, here's the thing. I have an 256GB SSD and a 2TB HDD in my system. I had windows 7 on the SSD until a couple of days ago and ubuntu on a partition on my HDD. Not so familiar with ubuntu btw, just getting into it.
I had some issuse with windows so I decided to switch to ubuntu full time, but I needed to keep windows for some essential software.
Ok, main story now. Ubuntu on SSD, no problem. Had windows on a partition on the HDD, but it didn't boot.
At this point I already switched to ubuntu and made both partitions of the HDD, the storage one and the windows one, auto-mount on startup.
I did this through the "Disks" application(program? idk, new to ubuntu). When I realized windows won't boot, I went to gparted, formated the partition, deleted it, recreated it and reinstalled windows on it, but I changed the name of the partition from "New Volume" to "windows".
Apparently, the setting that auto-mounts "New Volume" is still active and it's trying to mount a drive that no longer exists since I'm getting that message before startup.
How can I fix this? Is there some way I can see the list of auto-mounting drives in the terminal so I can delete them? I've googled for about 2 hours with nothing similar to my situation so I came here. Sorry if it's already been answered somewhere.
Thanks in advance.
EDIT:
natkoui@natko-ubuntu:~$ cat /etc/fstab
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
/dev/mapper/ubuntu--vg-root / ext4 noatime,errors=remount-ro 0 1
# /boot was on /dev/sda1 during installation
UUID=7786039f-4196-4d35-a746-35a2d2521e76 /boot ext2 defaults 0 2
/dev/mapper/ubuntu--vg-swap_1 none swap sw 0 0
/dev/disk/by-uuid/84DEFF8BDEFF7430 /media/natkoui/New\040Volume auto nosuid,nodev,nofail,x-gvfs-show 0 0
/dev/disk/by-uuid/64E66D6AE66D3D84 /media/natkoui/Storage auto nosuid,nodev,nofail,x-gvfs-show 0 0
/dev/disk/by-uuid/295E2E3F4411E9C2 /media/natkoui/windows auto nosuid,nodev,nofail,x-gvfs-show 0 0
