I have a problem with my Ubuntu OS that I've been trying to solve for the past 2 weeks with no results. I've probably put 14 hours into solving this problem.
When I use the suspend option on my computer, it breaks the operating system. The OS suspends as it normally should (dark screen, blinking power light, etc.) but it does not wake up properly. When I try to wake it up, the backlight turns on and the fan starts and everything but the screen is black. I've tried different key combinations (CTRL+ALT+F2 for example), putting in USB drives, pressing the power button, but none of it will turn the screen bright. The screen stays frozen black and the computer is running as if it were awake (fan whizzing and stuff).
I am forced to hard restart the system every time I choose the suspend option.
Hibernate is similar. When I type
sudo pm-hibernate
The computer will go dark, but will not power down. If I move the mouse it will turn back on to a black screen with a blinking cursor. CTRL+ALT+F2 will go to a terminal window, but upon typing anything in the terminal window will freeze.
I've tried a number of ideas including all of them here: Ubuntu freezes/crash after wake when upgraded to 13.10 and here: http://wafflesatnoon.com/2012/11/17/ubuntu-suspend-wont-wake-up-my-quest/
Help?
Ubuntu 13.10 on a HP Pavilion g6-2235us Trinity [Radeon HD 7520G] video driver
Jeff
  • 1,724
The same thing happens to me. I have researched that it was a driver problem. I can't do anything to get out of suspend or hibernate without force-restarting cinnamon (In my case, I have Linux Mint 17 cinnamon on an HP Pavilion g6 with AMD Trinity driver) by doing Ctrl+Alt+Backspace several times. THEN when that works, GRUB appears after a long wait, then everything works fine when you load Linux again. I have also heard Ctrl+Alt+F1 then Ctrl+Alt+F7 while suspended should work, though I have never tried it. Play with your drivers and test everything out if in doubt.
Jeff
  • 1,724
Try installing the fglrx driver : sudo apt-get install fglrx and then reboot.
Pranav Marathe
  • 361
