do-release-upgrade is part of the package “update-manager-core”. The script seems to determine which release you are going to upgrade to, try to find out if it’s supported or not and complain about the latter. – If it’s convinced to work, it downloads the release-specific UpgradeTool and runs it.
Part of the “update-manager-core” package is the file /etc/update-manager/meta-release, where you can find the URL http://changelogs.ubuntu.com/meta-release and there you find the URL for the UpgradeTool to download.
The downloaded UpgradeTool tarball is packaged from the source package “ubuntu-release-upgrader” (before it was “update-manager”). The version corresponds to the latest updates for the target release.
The source has an old README from warty and hoary release times. It discusses what should be done during a release upgrade. It also mentions a link to a more detailed UpgradeTool proposal.
I list here the actions mentioned there and checked if they are actually implemented:
- repository related
- switch to new sources.list entries
- remove unknown 3rd party repositories
- possibly swap mirror (not implemented)
- package related
- check there are no broken packages before upgrading
- update current release before upgrading (
apt-get update only)
- remove and install specific packages
- check if {ubuntu,kubuntu,edubuntu}-desktop is installed
- get rid of old kernels
- have a removal-blacklist and -whitelist
- remove or replace obsolete packages which existed in earlier releases
- configuration related (possible in quirks: see below)
- adding the default user to new groups (not done for the versions I checked)
- check some config files
The UpgradeTool is configured for each release using the following files (open them to see!):
- DistUpgrade.cfg
- UpgradeTool-related configuration
- release-related configuration
- repositories (e.g. [Sources] ValidMirrors)
- custom changes ([Distro] PostInstallScript)
- special packages; processed only by DistUpgradeController.py:
- [Distro] RemoveObsoletes, ForcedObsoletes, BaseMetaPkgs, MetaPkgs
- [meta_package_name] ForcedObsoletes
- ...and by DistUpgradeCache.py:
- [Distro] MetaPkgs, RemovalBlacklist, RemoveEssentialOk, BadVersions, BaseMetaPkgs, PurgeObsoletes, Demotions, KeyDependencies
- [Distro and meta_package_name] KeepInstalledPkgs, KeepInstalledSection, PostUpgrade*
- [KernelRemoval] *
- DistUpgradeQuirks.py
- runs (release) specific functions (same file) and plugins (
plugins directory)
- functions must have specific names (e.g.
from_nattyPreCacheOpen()) and plugins special condition attributes (e.g. * or PostInitialUpdate)
- one of those functions,
StartUpgrade(), is another grab-bag itself: among others it calls _applyPatches(), which goes over the files in the patches directory
- all these do pretty much nothing on my installation (i386, packages not older than natty-updates)
- more from DistUpgradeCache.py
- runs
get_kernel_list.sh (not in trusty) and makes sure one kernel is installed
- some handling about Nvidia drivers
Fazit:
do-release-upgrade will do little to nothing you can’t do with apt-get or aptitude etc.—Just a little smoother, especially if you are not experienced with challenging conflict resolutions in aptitude (and do not want to confront yourself with those).
Checked versions:
- natty → oneiric
- oneiric → precise
- precise → trusty (final as of 2014-04-18)
- trusty → utopic (hours before release on 2014-10-23)
