To answer the real question, about how to create your own application file, you only need to know that it is using windows INI file format.
[appname]
title=1-liner here
description=a longer line here
ports=1,2,3,4,5,6,7,8,9,10,30/tcp|50/udp|53
The ports line can specify multiple ports, with /udp or /tcp, to limit the protocol, otherwise it defaults to both. You have to split the protocol sections up with |.
So, for a real-life set of examples I made:
[puppet]
title=puppet configuration manager
description=Puppet Open Source from http://www.puppetlabs.com/
ports=80,443,8140/tcp
[AMANDA]
title=AMANDA Backup
description=AMANDA the Advanced Maryland Automatic Network Disk Archiver
ports=10080
You can list multiple versions of the app in a single file, like this one from apache:
===start of apache2.2-common file===
[Apache]
title=Web Server
description=Apache v2 is the next generation of the omnipresent Apache web server.
ports=80/tcp
[Apache Secure]
title=Web Server (HTTPS)
ports=443/tcp
[Apache Full]
title=Web Server (HTTP,HTTPS)
ports=80,443/tcp
===end of file===
Once you have defined your application file, put it in /etc/ufw/applications.d, then tell ufw to reload the application definitions with
ufw app update appname
ufw app info appname
Use it with something like:
ufw allow from 192.168.1.10 to any app amanda
ufw allow amanda
assuming 192.168.1.10 is the IP of your amanda server.
