I use gupnp-av-cp application to play, pause, volume up/down, stop in short to control media buttons on TV which is connected to local area network. But When I enable ufw firewall then it fails to reach TV.
I added a rule to /etc/ufw/applications.d/gupnp-av-cp
 [gupnp-av-cp]
 title=Media Controller
 description=Local Area Media
 ports=80,60999/tcp
reloaded ufw
 sudo ufw reload
but it doesn't work properly.
I don't know which port ranges to allow
kenn
  • 5,232
As far as I'm informed, you have just given ufw the information about a protocol. But now you have to enable it. You can perform this with the following command:
ufw app update gupnp-av-cp
ufw allow gupnp-av-cp
Then you can reload ufw and it should work.
Also consider looking at: how do you create an app profile for ufw?
MelcomX
  • 93
In my case I have to apply the following steps:
[gupnp-av-cp]
ports=80:60999/tcp|1900:60999/udp
Then
sudo ufw allow  from 192.168.1.110/24 to any app gupnp-av-cp
Finally
sudo ufw reload
You also need to enable UPNP in your modem. 192.168.1.110 is local ip address of my computer.
kenn
  • 5,232
