I have AVI Files that are videos. Im am looking to burn these movies onto a DVD-R. It only burns as data to the disc if I burn it directly. So im wondering what program will convert these AVI Files to burnable files to watch on DVD player?
A very simple program that do the trick is DeVeDe.
To install it, you can use the version in multiverse. Notice that I think that there is some strange interaction with the normal video packages (it will unisintall things like libavutil51 to install libavutil-extra-51... it works for me, but can have collateral effects that I do not know).
It is straightforward to use.
DeVeDe screenshot starting
If it happens that you have to remove it, I post here the installation log, so that if needed you can re-install the other packages.
The following extra packages will be installed:
  dvdauthor libavcodec-extra-53 libavformat-extra-53 libavutil-extra-51
  libpostproc-extra-52 libswscale-extra-2 mencoder
Suggested packages:
  mplayer-doc
The following packages will be REMOVED:
  libavcodec53 libavformat53 libavutil51 libpostproc52 libswscale2
The following NEW packages will be installed:
  devede dvdauthor libavcodec-extra-53 libavformat-extra-53 libavutil-extra-51
0 upgraded, 8 newly installed, 5 to remove and 0 not upgraded.
Need to get 6,391 kB of archives.
After this operation, 7,455 kB of additional disk space will be used.
Rmano
  • 32,167
