root@avidgamers:~/warcraft/aG-HostbotRU/ghost# apt-get install libmysql++-dev
Reading package lists... Done
Building dependency tree
E: Unable to locate package libmysql++-dev
E: Couldn't find any package by regex 'libmysql++-dev'
OS: Ubuntu LTS 12.04 64Bit
I've been able to install this package on numerous other servers, but it isn't downloading this package on this new server. I can, however, download and install other packages that I need. It may not make a difference, but the server is located in Moscow, Russia.
  1. First of all, run apt-get update. If you get any errors, edit your post and include the output. If you don't get errors, try installing the package again.
  2. If that doesn't work, check if you have universe repositories enabled: Open your software center and place your mouse cursor on the top of your desktop. In the menu that appears, click Edit >> Software sources. In the first tab (Ubuntu Software), check if universe is enabled. If it's not, then enable it and run apt-get update again and try installing the package again.
  3. If that doesn't work too, you should probably try another mirror. Follow the instructions in 2 and change the "Download from" combobox. You can see a list of the mirrors with information on how updated it is here: https://launchpad.net/ubuntu/+archivemirrors. That should help you choose one. Remember to choose one that's near you location.
If nothing of this works, edit your post including the contents of your /etc/apt/sources.list.
GabrielF
  • 665
The libmysql++-dev package is in the universe repository component. My guess is that it's not found because Universe isn't enabled on your system. So enable the universe repository, and you should be able to install it.
In general, when a package won't install even when it seems like you're doing all the right things, it's useful to make sure it's really available for the version of Ubuntu you're running, and what repository provides it. To do that, you can search for the package at http://packages.ubuntu.com/.
It's possible this is not the cause of the problem, of course. In that case, I recommend expanding your question with information about what you saw when you checked to see if Universe was enabled, as well as with the information requested by GabrielF.
Eliah Kagan
  • 119,640
