I just installed Ubuntu 12.04 over 10.04. It seemed to go OK until I tried running my updates. When I launch Software Center I get the following error message:
Items cannot be installed or removed until the package catalogue is repaired. Do you want to repair it now?
Once Update Manager has finished the repairs, you can close it and return to the store.
So I hit repair and then I get this message:
Package operation failed
The installation or removal of a software package failed.
So I hit OK and it goes back to the first error message
And it just continues repeating those two messages. How do I fix whatever is broken? I reviewed answers for similar questions. I tried the suggestions in that link but they did not work. I tried to post the results but, being new to this system I am not allowed to post more than 2 links. However, it seems the crux of the problem is this:
(Reading database ... 742676 files and directories currently installed.)
Removing libxml-libxml-perl ...
/var/lib/dpkg/info/libxml-libxml-perl.prerm: 11: /var/lib/dpkg/info/libxml-libxml-perl.prerm: update-perl-sax-parsers: not found
dpkg: error processing libxml-libxml-perl (--remove):
 subprocess installed pre-removal script returned error exit status 127
 libxml-libxml-perl
Bryan
I always recommend doing a clean installation. I don't have deep knowledge on this, but I think that you should delete all of the PPAs that you had registered before.
Then, run sudo apt-get update and reboot.
After rebooting, run sudo apt-get update again and then sudo apt-get upgrade.
If this doesn’t work, I think that there are programs that could be useful to remake your /etc/apt/sources.list.
chaskes
  • 15,536
When is a big update like that, I always recommend format HDDs and install all from 0, and with more reason if we are talking about Linux.
You can edit the two last lines of your /etc/apt/sources.list
And,
Try this:
sudo apt-get update
That will update your system software list.
And then,
sudo apt-get install -f
That should fix your packages.
If it doesn't, then you've got a broken package manager, and I'd recommend reinstalling - but only if you've tried everything else!!!
Also:
Try
sudo apt-get update
to update your package list. Then
sudo apt-get autoclean
to clean up any partial packages. Then
sudo apt-get clean
to clean up the apt cache.
sudo apt-get autoremove
will clean up any unneeded dependencies. If while doing this you can identify the broken package this code will very forcefully remove it.
sudo dpkg --remove -force --force-remove-reinstreq package name
Change package name to the real name of course.
Regards!
