Maybe i don't understand the system. Upgraded to (reinstalled) Ubuntu 11.04.
Is there any way the applications can use something that i set in nautilus, or it's just a wrong idea about the usage?
In nautilus the file association works great, easy, handy and so on...
My first problem was when installed chromium. Downloaded a file, a popup ask for assocation, set nautilus. And it only opens folder, for any file show an error: it is not a direcrory. Ok, so i thought Google chrome changed, because previously .pdf open acrobat,.torrent open vuze and so on. But now i have to open nautilus on download folder with it, than select and open the preferable application by manually and can't use any automatism i used to.
Then in gnome commander , it not followed the default association i set in nautilus. Ok maybe it is commander fault. use it's own.
Then in calibre, the "read" use again this default "can't open its not a directory" error
So it's seems to me the applications not using well this file associations or i really don't understand the aim of file associations system (mime,.desktop files,...)
If there is no solution i think i have to search some program (if any exist's) which can identify and launch application and set as default instead nautilus.
Luis Alvarado
  • 216,643
Julius
  • 41
5 Answers5
Comment out the line in .local/share/applications/mimeapps.list
inode/directory=rhythmbox.desktop;vlc.desktop;smplayer.desktop;
and insert
inode/directory=nautilus-folder-handler.desktop;
Mateo
  • 8,152
Remove or comment out (by adding "#" in front of the line)
x-scheme-handler/file=exo-file-manager.desktop
from this file:
Credits to Stop folders opening with different application than the file manager and UbuntuForums: Can't open files directly from Chrome - opens Nautilus for the link
Petros
You have to edit the .desktop file from that application and add the mime type
e.g. (the examples below are from an application that i had to fix myself)
[Desktop Entry]
Encoding=UTF-8
Name=Guitar Pro 6
Comment=Tablature Edition Software
Exec=GuitarPro6 %u
Terminal=false
X-MultipleArgs=false
Type=Application
Categories=Application;AudioVideo;
MimeType=audio/x-gtp;
The last line from the example shows the association.
If you want to create a new mimetype you should do this: Create a new file at /usr/share/mime/packages/
e.g. GuitarPro6.xml
<?xml version="1.0" encoding="UTF-8"?>
<mime-info xmlns="http://www.freedesktop.org/standards/shared-mime-info">
    <mime-type type="audio/x-gtp">
        <comment>Guitar Pro tab</comment>
            <glob pattern="*.gpx"/>
            <glob pattern="*.gp3"/>
            <glob pattern="*.gp4"/>
            <glob pattern="*.gp5"/>
        </mime-type>
</mime-info>
After you create the file just run sudo update-mime-database /usr/share/mime/
demel
  • 468
I've created the vue.xml and vue.desktop file, updated the mime type database with:
but received the error
Unknown media type in type 'office/vue'
Then I changed the <mime-type type="office/vue"> and MimeType=office/vue to <mime-type type="application/vue"> and MimeType=application/vue, and that worked.
Correct mime type file is:
        <comment>Vue file</comment>
            <glob pattern="*.vue"/>
            <glob pattern="*.vpk"/>
        </mime-type>
</mime-info>
And my *.desktop file was:
[Desktop Entry]
Encoding=UTF-8
Name=VUE
Categories=Office
Exec=java -jar /usr/share/VUE/VUE.jar
Icon=/usr/share/VUE/vue.gif
StartupNotify=false
Terminal=false
Type=Application
Comment=Visual Understanding Environment Application
StartupWMClass=tufts-vue-VUE
Fabby
  • 35,017
Sardinha
  • 228
  • 15
I had the same problem. I found the solution on another forum.
To make short:
uninstall exo-utils (and all dependencies).
It worked for me!
Jona
