Well I checked and SO are the two Ubuntu 12.04 and Windows 7 Ultimate. but after restart the screen goes black for about 15 seconds and then start Ubuntu. Even not to do to bring up the Grub. Since the probe Boot-disk-repair-tool and this is the result I get:
http://paste.ubuntu.com/6729018/
thanks
When ubuntu is installed it overites the bootloader and installs GRUB (the software that offers you the OS selection at boot)
First you need to reinstall ubuntu to have a working OS which you can make the changes on.
To add windows 7 to the GRUB menu:
First, you will need to know which of the NTFS partitions. You can test by mounting each and see what they contain. Generally you're looking for whatever contains Windows/ .
Once you know which partition that is (i.e., /dev/sda5), reduce that number by one. That number will be replaced with the "4" in "rootnoverify (hd0,4)"
Then enter this into /boot/grub/grub.conf [if that doesn't show up, /boot/grub/menu.lst]
title Windows
makeactive
chainloader +1
user36976
  • 551
