I'd like to use a Canon LIDE 110 scanner under Ubuntu 10.
Here are the results of lsusb and sane-find-scanner:
$ lsusb
Bus 008 Device 002: ID 1532:001a Razer USA, Ltd
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 003: ID 0471:0602 Philips ATI Remote Wonder II Input Device
Bus 007 Device 002: ID 1532:0019 Razer USA, Ltd
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 004: ID 0dc6:5300 Precision Squared Technology Corp.
Bus 006 Device 003: ID 0dc6:5000 Precision Squared Technology Corp.
Bus 006 Device 002: ID 1532:001b Razer USA, Ltd
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 007: ID 04a9:1909 Canon, Inc.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
And
$ sudo sane-find-scanner
  # sane-find-scanner will now attempt to detect your scanner. If the
  # result is different from what you expected, first make sure your
  # scanner is powered up and properly connected to your computer.
  # No SCSI scanners found. If you expected something different, make sure tha
  # you have loaded a kernel SCSI driver for your SCSI adapter.
  # No USB scanners found. If you expected something different, make sure that
  # you have loaded a kernel driver for your USB host controller and have setu
  # the USB system correctly. See man sane-usb for details.
  # SANE has been built without libusb support. This may be a reason
  # for not detecting USB scanners. Read README for more details.
  # Not checking for parallel port scanners.
  # Most Scanners connected to the parallel port or other proprietary ports
  # can't be detected by this program.
All my problems were gone after Oneiric (11.10) installation.
Actually I didn't test with 11.04.
