I have brought a Thinkpad T440s from Lenovo and installed Ubuntu 13.10 on it. It works good, but there is one big issue: Often the mouse freezes after a click for a few seconds and sometimes the mouse freezes forever until I remove the psmouse module and re-add it:
sudo modprobe -r psmouse
sudo modprobe psmouse
After that the touchpad starts working again normally, if it is still frozen I have to reboot the laptop. I am not sure, but could that be a problem with the driver? Here is interesting part of the dmesg output:
[  531.369723] psmouse serio1: bad data from KBC - timeout
[  531.386334] psmouse serio1: TouchPad at isa0060/serio1/input0 lost sync at byte 1
[  531.388140] psmouse serio1: bad data from KBC - timeout
[  531.396685] psmouse serio1: bad data from KBC - timeout
[  531.399687] psmouse serio1: TouchPad at isa0060/serio1/input0 lost sync at byte 4
[  531.400798] psmouse serio1: TouchPad at isa0060/serio1/input0 lost sync at byte 1
[  531.407985] psmouse serio1: TouchPad at isa0060/serio1/input0 - driver resynced.
[  920.895669] psmouse serio1: TouchPad at isa0060/serio1/input0 lost sync at byte 1
[  920.908302] psmouse serio1: TouchPad at isa0060/serio1/input0 - driver resynced.
[ 1116.953171] psmouse serio1: bad data from KBC - timeout
[ 1117.204120] psmouse serio1: TouchPad at isa0060/serio1/input0 lost sync at byte 1
[ 1117.205379] psmouse serio1: TouchPad at isa0060/serio1/input0 lost sync at byte 1
[ 1117.206550] psmouse serio1: TouchPad at isa0060/serio1/input0 lost sync at byte 1
[ 1117.207728] psmouse serio1: TouchPad at isa0060/serio1/input0 lost sync at byte 1
[ 1117.208919] psmouse serio1: TouchPad at isa0060/serio1/input0 lost sync at byte 1
[ 1117.208929] psmouse serio1: issuing reconnect request
[ 1173.743451] psmouse serio1: bad data from KBC - timeout
[ 1173.974331] psmouse serio1: TouchPad at isa0060/serio1/input0 lost sync at byte 4
[ 1173.975528] psmouse serio1: TouchPad at isa0060/serio1/input0 lost sync at byte 1
[ 1173.976673] psmouse serio1: TouchPad at isa0060/serio1/input0 lost sync at byte 1
[ 1173.977828] psmouse serio1: TouchPad at isa0060/serio1/input0 lost sync at byte 1
[ 1173.979044] psmouse serio1: TouchPad at isa0060/serio1/input0 lost sync at byte 1
[ 1173.979054] psmouse serio1: issuing reconnect request
[ 1231.478893] psmouse serio1: TouchPad at isa0060/serio1/input0 lost synchronization, throwing 3 bytes away.
[ 1308.995128] psmouse serio1: bad data from KBC - timeout
[ 1457.439552] psmouse serio1: bad data from KBC - timeout
[ 1820.123546] psmouse serio1: TouchPad at isa0060/serio1/input0 lost sync at byte 4
[ 1820.124699] psmouse serio1: TouchPad at isa0060/serio1/input0 lost sync at byte 1
[ 1820.125855] psmouse serio1: TouchPad at isa0060/serio1/input0 lost sync at byte 1
[ 1820.127023] psmouse serio1: TouchPad at isa0060/serio1/input0 lost sync at byte 1
[ 1820.128171] psmouse serio1: TouchPad at isa0060/serio1/input0 lost sync at byte 1
[ 1820.128182] psmouse serio1: issuing reconnect request
Can somebody help me?
flammi88
  • 143
This is a hardware issue, and should be reproducible in other operating systems (like Windows 7). The Windows 8 drivers apparently have some sort of workaround (maybe faster reconnecting or ignoring of these error conditions). The issue (at least in my case) is easy to fix - the touchpad cable moves around and becomes disconnected when I press the touchpad button - you should be able to confirm this by determine if you only see the errors shown above when you push the touchpad down.
The solution is to either have Lenovo replace the touchpad, or fix it yourself. In my case, I rerouted the touchpad cable under the battery in a manner such that when I push the touchpad the cable does not come loose. This took only a few minutes, so if you've already opened the bottom of your laptop you probably don't have anything to lose.
I can also confirm that it is a hardware issue. Attempts to reroute the touchpad cable weren't successful. The touchpad exchange fixed it.
benk
Install the indicator-cpufreq package (sudo apt-get install indicator-cpufreq) than reboot. It has solved the problem for me.
See this mailing.
A fix working for me is given here: Touchpad stopped working out of the blue
Create a configuration file for the touchpad:
sudo -H gedit /etc/modprobe.d/touchpad.conf
Add this to the file:
options psmouse proto=imps
SAVE file.
REBOOT
This is on a T440s
Zanna
  • 72,312
