I'm pretty new to Linux, but over the past few days I've taken it upon myself to give it a shot. I'm trying a few different distributions just to kind of get a feel for different versions, and this is the only thing that's really got me hung up.
I started with Windows 7, then I installed Ubuntu 13.10 (which works perfectly), and then I installed Linux Mint. However, I don't have a way to boot Linux Mint, and that's what I'd like to accomplish. My goal is to have a Linux Mint menu entry on the Grub2 menu that appears on startup to goes along with the Ubuntu and Windows 7 menu entries (and a few others that I have yet to use, like the Advanced Ubuntu Options submenu, and the memtest menu entry).
In case any of this information is needed, here's some information from the GParted partition table, as well as parts of the bootinfoscript output:
Partitions info and descriptions taken from GParted:
/dev/sda1is a 101.94 MiB primary partition with fat16 file system with a flag of "diag"/dev/sda2is a 11.29 GiB primary partition with ntfs file system with a flag of "boot" and a label of "RECOVERY." According to/boot/grub/grub.cfg, this is where the Windows 7 loader resides. I have no issues booting into Windows 7 from the current Grub2 menu./dev/sda3is a 275.12 GiB primary partition with ntfs file system with a label of "OS." This partition holds all of my files that were originally made on Windows, though some have been saved over using Ubuntu programs (nothing went wrong editing files across operating systems so far but let me know if this is bad for whatever reason)./dev/sda4is a 171.01 GiB extended partition. This partition is currently mounted. This contains the swap partition, in addition to logical partitions for the Ubuntu 13.10 and Linux Mint 16:/dev/sda5is a 58.79 GiB logical partition with ext4 file system, which contains the installation of Linux Mint 16. In GParted, it says the mount point for this file system is/. This is the only partition that has a non-empty mount point entry. I don't know what to make of that, and I also currently do not know of a way to boot Linux Mint 16 as it currently resides./dev/sda6is a 19.56 GiB partition (I believe it's considered primary?) with "linux-swap" file system. This was created automatically when I installed Ubuntu, but I increased its size manually by about 10 GB when I was having a few issues trying to install Linux Mint 16. Linux Mint 16 is currently successfully installed as far as I can tell, but I don't know how to boot into it like I said before. This partition is currently mounted./dev/sda7is a 36.41 GiB logical partition with ext4 file system, which contains Ubuntu 13.10. Ubuntu 13.10 works quite well, and it's what I'm currently writing this question in. This partition is currently mounted.
Here is the bootinfoscript output (it's quite long, and includes the grub.cfg file as well as the sudo fdisk -l info already posted here - some had to be omitted due to character limitations, however):
Boot Info Script 0.61 [1 April 2012]
============================= Boot Info Summary: ===============================
=> Grub2 (v1.99) is installed in the MBR of /dev/sda and looks at sector 1 of
the same hard drive for core.img. core.img is at this location and looks
in partition 94 for .
=> Syslinux MBR (4.04 and higher) is installed in the MBR of /dev/sdb.
sda1: __________________________________________________________________________
File system: vfat
Boot sector type: Dell Utility: FAT16
Boot sector info: No errors found in the Boot Parameter Block.
Operating System:
Boot files: /DELLBIO.BIN /DELLRMK.BIN /COMMAND.COM
sda2: __________________________________________________________________________
File system: ntfs
Boot sector type: Windows Vista/7: NTFS
Operating System:
Boot files: /bootmgr /Boot/BCD
sda3: __________________________________________________________________________
File system: ntfs
Operating System: Windows 7
Boot files: /Windows/System32/winload.exe /ubuntu/winboot/wubildr
/ubuntu/winboot/wubildr.mbr
sda4: __________________________________________________________________________
File system: Extended Partition
Boot sector type: -
Boot sector info:
sda5: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System: Ubuntu 13.10
Boot files: /boot/grub/grub.cfg /etc/fstab
sda6: __________________________________________________________________________
File system: swap
Boot sector type: -
Boot sector info:
sda7: __________________________________________________________________________
File system: ext4
Boot sector type: Grub2 (v1.99)
Boot sector info: Grub2 (v1.99) is installed in the boot sector of sda7
and looks at sector 648107560 of the same hard drive
Operating System: Linux Mint 16 Petra
============================ Drive/Partition Info: =============================
Drive: sda _____________________________________________________________________
Disk /dev/sda: 500.1 GB, 500107862016 bytes
255 heads, 63 sectors/track, 60801 cylinders, total 976773168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
Partition Boot Start Sector End Sector # of Sectors Id System
/dev/sda1 63 208,844 208,782 de Dell Utility
/dev/sda2 * 212,992 41,172,991 40,960,000 7 NTFS / exFAT / HPFS
/dev/sda3 41,172,992 618,134,175 576,961,184 7 NTFS / exFAT / HPFS
/dev/sda4 618,139,646 976,771,071 358,631,426 5 Extended
/dev/sda5 694,501,376 817,790,975 123,289,600 83 Linux
/dev/sda6 935,753,728 976,771,071 41,017,344 82 Linux swap / Solaris
/dev/sda7 618,139,648 694,499,022 76,359,375 83 Linux
"blkid" output: ________________________________________________________________
Device UUID TYPE LABEL
/dev/sda1 3030-3030 vfat DellUtility
/dev/sda2 76C2AD13C2ACD89F ntfs RECOVERY
/dev/sda3 B864AE8864AE4948 ntfs OS
/dev/sda5 5832ede3-f357-427e-ac67-b2157b5ba6e1 ext4
/dev/sda6 24a1b8d2-d3a0-4b3f-b48e-9a3f5bab16c2 swap
/dev/sda7 520dfeb8-758e-47c0-97de-a0a8cb8b4866 ext4
================================ Mount points: =================================
Device Mount_Point Type Options
/dev/sda3 /media/matt/OS fuseblk (rw,nosuid,nodev,allow_other,default_permissions,blksize=4096)
/dev/sda5 / ext4 (rw,errors=remount-ro)
/dev/sda7 /media/matt/520dfeb8-758e-47c0-97de-a0a8cb8b4866 ext4 (rw,nosuid,nodev,uhelper=udisks2)
=========================== sda5/boot/grub/grub.cfg: ===========================
Bootinfoscript
# DO NOT EDIT THIS FILE
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
set have_grubenv=true
load_env
fi
set default="0"
if [ x"${feature_menuentry_id}" = xy ]; then
menuentry_id_option="--id"
else
menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function recordfail {
set recordfail=1
if [ -n "${have_grubenv}" ]; then if [ -z "${boot_once}" ]; then save_env recordfail; fi; fi
function load_video {
if [ x$feature_all_video_module = xy ]; then
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
if [ x$feature_default_font_path = xy ] ; then
font=unicode
else
insmod part_msdos
insmod ext2
set root='hd0,msdos5'
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos5 --hint-efi=hd0,msdos5 --hint-baremetal=ahci0,msdos5 5832ede3-f357-427e-ac67-b2157b5ba6e1
else
search --no-floppy --fs-uuid --set=root 5832ede3-f357-427e-ac67-b2157b5ba6e1
fi
font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
set gfxmode=auto
load_video
insmod gfxterm
set locale_dir=$prefix/locale
set lang=en_US
insmod gettext
fi
terminal_output gfxterm
if [ "${recordfail}" = 1 ]; then
set timeout=-1
else
set timeout=10
fi
### END /etc/grub.d/00_header ###
/\/\/\/\/\ EDITED OUT MORE THEME INFO /\/\/\/\/\/\
### BEGIN /etc/grub.d/10_linux ###
function gfxmode {
set gfxpayload="${1}"
if [ "${1}" = "keep" ]; then
set vt_handoff=vt.handoff=7
else
set vt_handoff=
fi
if [ "${recordfail}" != 1 ]; then
if [ -e ${prefix}/gfxblacklist.txt ]; then
if hwmatch ${prefix}/gfxblacklist.txt 3; then
if [ ${match} = 0 ]; then
set linux_gfx_mode=keep
else
set linux_gfx_mode=text
fi
else
fi
else
fi
else
fi
export linux_gfx_mode
menuentry 'Ubuntu' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-5832ede3-f357-427e-ac67-b2157b5ba6e1' {
recordfail
load_video
gfxmode $linux_gfx_mode
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-3.11.0-15-generic root=UUID=5832ede3-f357-427e-ac67-b2157b5ba6e1 ro acpi_backlight=vendor dell_laptop.backlight=0 quiet splash $vt_handoff
initrd /boot/initrd.img-3.11.0-15-generic
/\/\/\/\/\/\/\/ I MANUALLY OMITTED THE UBUNTU ADVANCED OPTIONS SUBMENU FROM HERE BECAUSE THERE Was >30000 CHARACTERS /\/\/\/\/\/\/
--class gnu --class os $menuentry_id_option 'gnulinux-3.8.0-35-generic-advanced-5832ede3-f357-427e-ac67-b2157b5ba6e1' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
echo 'Loading Linux 3.8.0-35-generic ...'
linux /boot/vmlinuz-3.8.0-35-generic root=UUID=5832ede3-f357-427e-ac67-b2157b5ba6e1 ro acpi_backlight=vendor dell_laptop.backlight=0 quiet splash $vt_handoff
echo 'Loading initial ramdisk ...'
initrd /boot/initrd.img-3.8.0-35-generic
menuentry 'Ubuntu, with Linux 3.8.0-35-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-3.8.0-35-generic-recovery-5832ede3-f357-427e-ac67-b2157b5ba6e1' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-3.8.0-35-generic root=UUID=5832ede3-f357-427e-ac67-b2157b5ba6e1 ro recovery nomodeset
menuentry 'Ubuntu, with Linux 3.8.0-19-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-3.8.0-19-generic-advanced-5832ede3-f357-427e-ac67-b2157b5ba6e1' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
echo 'Loading Linux 3.8.0-19-generic ...'
linux /boot/vmlinuz-3.8.0-19-generic root=UUID=5832ede3-f357-427e-ac67-b2157b5ba6e1 ro acpi_backlight=vendor dell_laptop.backlight=0 quiet splash $vt_handoff
initrd /boot/initrd.img-3.8.0-19-generic
menuentry 'Ubuntu, with Linux 3.8.0-19-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-3.8.0-19-generic-recovery-5832ede3-f357-427e-ac67-b2157b5ba6e1' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-3.8.0-19-generic root=UUID=5832ede3-f357-427e-ac67-b2157b5ba6e1 ro recovery nomodeset
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/20_memtest86+ ###
menuentry 'Memory test (memtest86+)' {
insmod part_msdos
insmod ext2
else
fi
linux16 /boot/memtest86+.bin
menuentry 'Memory test (memtest86+, serial console 115200)' {
insmod part_msdos
insmod ext2
else
fi
linux16 /boot/memtest86+.bin console=ttyS0,115200n8
### END /etc/grub.d/20_memtest86+ ###
### BEGIN /etc/grub.d/30_os-prober ###
menuentry 'Windows 7 (loader) (on /dev/sda2)' --class windows --class os $menuentry_id_option 'osprober-chain-76C2AD13C2ACD89F' {
insmod part_msdos
insmod ntfs
set root='hd0,msdos2'
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos2 --hint-efi=hd0,msdos2 --hint-baremetal=ahci0,msdos2 76C2AD13C2ACD89F
else
search --no-floppy --fs-uuid --set=root 76C2AD13C2ACD89F
fi
chainloader +1
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/30_uefi-firmware ###
### END /etc/grub.d/30_uefi-firmware ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f ${config_directory}/custom.cfg ]; then
source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
=============================== sda5/etc/fstab: ================================
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sdb5 during installation
UUID=5832ede3-f357-427e-ac67-b2157b5ba6e1 / ext4 errors=remount-ro 0 1
# swap was on /dev/sdb6 during installation
UUID=24a1b8d2-d3a0-4b3f-b48e-9a3f5bab16c2 none swap sw 0 0
=========================== sda7/boot/grub/grub.cfg: ===========================
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
load_env
fi
set default="0"
else
fi
set boot_once=true
fi
fi
set recordfail=1
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
font=unicode
else
insmod part_msdos
insmod ext2
set root='hd0,msdos7'
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos7 --hint-efi=hd0,msdos7 --hint-baremetal=ahci0,msdos7 520dfeb8-758e-47c0-97de-a0a8cb8b4866
else
search --no-floppy --fs-uuid --set=root 520dfeb8-758e-47c0-97de-a0a8cb8b4866
fi
fi
set gfxmode=auto
load_video
insmod gfxterm
set lang=en_US
insmod gettext
fi
set timeout=-1
else
set timeout=10
fi
/\/\/\/\/\/\/ EDITED OUT SOME DEBIAN/MINT THEME INFO HERE /\/\/\/\/\/\/\
function gfxmode {
set gfxpayload="$1"
if [ "$1" = "keep" ]; then
else
set vt_handoff=
fi
if [ ${recordfail} != 1 ]; then
else
fi
else
fi
else
fi
else
fi
if [ "$linux_gfx_mode" != "text" ]; then load_video; fi
menuentry 'Linux Mint 16 Cinnamon 64-bit, 3.11.0-12-generic (/dev/sda7)' --class ubuntu --class gnu-linux --class gnu --class os {
recordfail
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-3.11.0-12-generic root=UUID=520dfeb8-758e-47c0-97de-a0a8cb8b4866 ro quiet splash $vt_handoff
initrd /boot/initrd.img-3.11.0-12-generic
menuentry 'Linux Mint 16 Cinnamon 64-bit, 3.11.0-12-generic (/dev/sda7) -- recovery mode' --class ubuntu --class gnu-linux --class gnu --class os {
recordfail
insmod gzio
insmod part_msdos
insmod ext2
else
fi
echo 'Loading Linux 3.11.0-12-generic ...'
linux /boot/vmlinuz-3.11.0-12-generic root=UUID=520dfeb8-758e-47c0-97de-a0a8cb8b4866 ro recovery nomodeset
### BEGIN /etc/grub.d/10_lupin ###
### END /etc/grub.d/10_lupin ###
insmod part_msdos
insmod ext2
else
fi
insmod part_msdos
insmod ext2
else
fi
insmod part_msdos
insmod ntfs
else
fi
chainloader +1
menuentry 'Ubuntu 13.10 (13.10)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-simple-5832ede3-f357-427e-ac67-b2157b5ba6e1' {
insmod part_msdos
insmod ext2
else
fi
/\/\/\/\/\/\/ THERE WAS ANOTHER SUBMENU THING FOR UBUNTU ADVANCED OPTIONS HERE, ALSO OMITTED /\/\/\/\/\/\/\/\
fi
=============================== sda7/etc/fstab: ================================
# / was on /dev/sda7 during installation
UUID=520dfeb8-758e-47c0-97de-a0a8cb8b4866 / ext4 errors=remount-ro 0 1
# swap was on /dev/sda6 during installation
I'm not sure if this partition setup is good or not, because I was unable to create an additional primary partition (4 max), but I figured since Ubuntu could boot from within the extended partition, Linux Mint should be able to as well, so I added Linux Mint to a partition in the same extended partition as Ubuntu (which is in /dev/sda5), but in its own logical partition /dev/sda7.
In the /boot/grub/grub.cfg file, there are several menuentry units. If the right way to go about booting Linux Mint from the Grub2 menu is to just add a menuentry block for Linux Mint, then I'd like to know how to do this. If there's a better way to get each of these operating systems to have an option to be booted on startup, let me know that as well!
I saw a somewhat similar question here but it seemed a little bit different since that user didn't have two operating system partitions contained within the same extended partition, and I didn't want to just be shooting in the dark and possibly break something important by accident.
If any more information is needed that I haven't given here, I'll be keeping a close eye on this so let me know right away and I'll do my best to provide you with whatever info you need.
Thank you very much for any help!
