I have windows 8 and ubuntu 12.04 LTS dual booted.. however, I have a partition with Windows 7 which does not have an entry in bootloader. How can I manually edit the GRUB so that I can get Windows 7, 8 as well as Ubuntu?
            Asked
            Active
            Viewed 3.5k times
-1
        You can Manually edit the Grub configuration easily by following these Steps,
However, if you have another partition in the same disk or another disk, you can try by @Reparing@ GRUB from the LTS media. Which sholud technically detect the other OS. If this doesnt help, only then head to edit the Config.
        Nocturnalknight
- 180
