I was trying to create this symbolic link:
sudo ln -s /usr/share/phpmyadmin /var/www/phpmyadmin
but I accidentally typed:
sudo ln -s /usr/share/php,yad,in /var/www/phpmyadmin
So now I want to correct it but it says symbolic link already exist.
You can use rm to delete the symlink.
Example:
-rw-rw-r-- 1 2014-01-02 09:21 tmo
lrwxrwxrwx 1 2014-01-02 09:21 tmo2 -> tmo
Then ...
rm tmo2
will remove the symlink.
Suppose you were trying to do:
sudo ln -s /usr/share/phpmyadmin /var/www/phpmyadmin/
but accidentally did:
sudo ln -s /usr/share/somethingelse /var/www/phpmyadmin/
To correct it simply navigate to the folder where the link is and unlink
cd /var/www/phpmyadmin/
~:# unlink somethingelse
A small caveat I found was that I was trying to run rm and unlink on a symlink and I was getting an error that it was a directory.
$ rm folder_name/
rm: cannot remove ‘folder_name/’: Is a directory
$ unlink folder_name/
unlink: cannot unlink ‘folder_name/’: Not a directory
To remove the symlink, I used unlink folder_name. It was failing as there was a trailing / which causes the file to appear to be a directory.
You can use the following to remove the symbolic link
sudo rm /usr/share/php,yad,in
rm is the terminal command to remove a file. See rm --help for more options that it can take.sudo is used because the symbolic link was created with sudo. The file therefore belongs to root and your normal user will not have permission to edit/remove it (you would be able to force this if you had write permission on the directory, which would not be the case here).Also see this post and my comment to the first answer to access phpmyadmin when getting a not found error after install.
I stumbled here because I had to remove a dpkg-divert and the new package won't install until it was removed.
So if you have done something like this:
sudo dpkg-divert --add --rename --divert /usr/bin/gcc.real /usr/bin/gcc
You need to remove it with something like this:
sudo dpkg-divert --remove /usr/bin/gcc.real
