15
What I want to do at all, is that: Create script that has icon on it. So I know only one way - file.desktop file with icon. Settings icon on it was successful, but I have no luck setting EXEC value :/
Can someone explain me a bit how to create executable script with icon on it? create .desktop file and link it to that script? Can someone give me structure of that .desktop file?
Erikas
  • 681
You didn't mention what you have tried, so try this:
[Desktop Entry]
Name=someName
Comment=
Exec=/path/to/script.sh
Icon=/path/to/icon
Terminal=false
Type=Application
Make sure that your script is executable, like this:
sudo chmod +x /path/to/script.sh
It also won't work with if your script uses the sudo command, or anything else that requires user input.
If you want it to open a terminal window when you run it (if you needed to add input or watch the output) set Terminal to true.
Terminal=true
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
Seth
  • 59,332
Use gnome-desktop-item-edit :
gnome-desktop-item-edit --create-new /path/to/new/launcher
# Usually, one does (create launcher in current directory) :
gnome-desktop-item-edit --create-new .
You'll be graphically prompted for those settings. Here's one of my launcher, which I created with this tool :
#!/usr/bin/env xdg-open
[Desktop Entry]
Version=1.0
Type=Application
Terminal=false
Icon[en_GB]=/path/to/icon/for/en_GB.png
Name[en_GB]=Name_for_en_GB
Exec=/path/to/shell/script.sh
Comment[en_GB]=Some comment for en_GB
Name=Launcher Name
Comment=Some comment.
Icon=/path/to/icon/file.png
The en_GB specific settings are not mandatory. Feel free to fill in with identical values.
Make sure the first command of the bash script is cd "${0%/*}" if nothing appears: this command changes the current working dir into the directory containing the script as most shell scripts work with relative paths starting from their dir.
Zac
  • 200
Make a file called testicon.desktop and place it on the desktop
$ more testicon.desktop
[Desktop Entry]
Version=1.0
Type=Application
Terminal=true
Icon=/home/robin/Desktop/testicon.png
Name=TestIcon
Exec=/home/robin/Desktop/testicon.sh
Comment=Some comment for en_GB
Name=TestIcon
Here is an executable bash script. Place it on your desktop and run it and it will describe making an icon that runs a script
$ more testicon.sh
#!/bin/bash
this forces bash to use the Desktop directory i.e. where this bash script is located
cd "${0%/*}"
echo "to make a shell script run from an icon" echo " make a file like this " sleep 1 echo "=====================================================" cat ./testicon.desktop echo "=====================================================" echo "called something like testicon.desktop" sleep 2 echo " chmod +x the .desktop file" echo " make a png file for the icon call it testicon.png" echo " now right click on .desktop file and allow launching" echo "should work" sleep 10 echo "bye, disapparing in ten seconds" sleep 10 NUC 2023-11-16_16:05 ~/Desktop
This works for
$ cat /etc/os-release
NAME="Ubuntu"
VERSION="20.04.6 LTS (Focal Fossa)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 20.04.6 LTS"
VERSION_ID="20.04"
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
VERSION_CODENAME=focal
UBUNTU_CODENAME=focal
Robin
  • 149
