When I change brightness on the laptop with a laptop keys the brightness is behaving strangely for a couple of minutes, and Xorg eats 5% CPU during this time.
I had the same effect on my previous laptop, which I attributed to its dying hardware. Now I get the same issue after a year usage of my new laptop.
On the first laptop I used proprientary ATI Radeon drivers, and on the current one I use proprientary NVIDIA drivers.
I'm currently using a Kubuntu-dev, but on the old laptop I've used a stable release.
I found a somewhat similar old thread on ubuntu forums with none responces.
Edit
I tried adjusting brightness from cli (see here and there) and also using gui wigdet (I'm on KDE) -- but nothing works: sloppy state frees me faster -- but doesn't change the brightness.
The brightness is only changed with laptop brightness keys, and it takes a couple of minutes to complete that 5% CPU Xorg task.
Adobe
  • 3,971
Solved!
$ find /sys -name "max_brightness"
/sys/devices/pci0000:00/0000:00:02.0/drm/card0/card0-LVDS-1/intel_backlight/max_brightness
/sys/devices/pci0000:00/0000:00:1c.1/0000:03:00.0/leds/phy0-led/max_brightness
/sys/devices/platform/dell-laptop/backlight/dell_backlight/max_brightness
$ cat /sys/devices/pci0000:00/0000:00:02.0/drm/card0/card0-LVDS-1/intel_backlight/max_brightness
4648
$ sudo bash -c 'echo 2000 >> /sys/devices/pci0000:00/0000:00:02.0/drm/card0/card0-LVDS-1/intel_backlight/brightness'
# note that now it is brightness - not max_brightness
This changes brightness right away! Just as before.
However I still don't know what was wrong.
Edit
The solution might be easily scripted. The only drawback -- it requires root, and I've no idea how to propely set up PolicyKit to do without it.
Edit 2:
I'm using the following script. It has two hardcoded values: Max and BrightnessFile found on lines 17 and 18:
#!/bin/bash
# to get description use the -h flag
# exit after a single error:
set -e
## default values:
Inc=
Dec=
Set=
Get=false
Max=4648 # max_brightness
BrightnessFile=/sys/devices/pci0000:00/0000:00:02.0/drm/card0/card0-LVDS-1/intel_backlight/brightness
Current=`cat $BrightnessFile`
## preambula:
PROGNAME=${0##*/}
PROGVERSION=0.01
noColors=false
usage()
cat << EO
usage: $PROGNAME [OPTIONS...]
Changes brightness of the laptop.
The value of the max brightness depends on the hardware, and is hardcoded. On my machine it is 4648:
  4648
Requires superuser privilages.
Examples:
  Increase brightness by 10 percents:
    $PROGNAME --inc 10
  Decrease brightness by 10 percents:
    $PROGNAME --dec 10
  Set brightness to 10 percents:
    $PROGNAME --set 10
optional arguments:
EO
cat << EO | column -s\& -t
  -i, --inc & increase brightness (in percents)
  -d, --dec & decrease brightness (in percents)
  -s, --set & set brightness (in percents)
  -g, --get & print current value (in percents)
  -G, --GUI & ask password with kdialog
  -h, --help & show this output
  -v, --version & show version information
EO
SHORTOPTS="hvi:d:s:g"
LONGOPTS="help,version,inc:,dec:,set:get"
ARGS=$(getopt -s bash --options $SHORTOPTS --longoptions $LONGOPTS --name $PROGNAME -- "$@")
eval set -- "$ARGS"
while true; do
    case $1 in
        -i|--inc)
            Inc=$2; shift;;
        -d|--dec)
            Dec=$2; shift;;
        -s|--set)
            Set=$2; shift;;
        -g|--get)
            Get=true;;
        -h|--help)
            usage; exit 0;;
        -v|--version)
            echo "$PROGVERSION"; exit 0;;
            shift; break;;
            shift; break;;
    esac
    shift
done
## program:
if $Get; then
    CurrentRelVal=`bc <<< "$Current*100/$Max"`
    echo "Current brightness: $CurrentRelVal%"
    exit 0
elif [ -n "$Inc" -a $Inc -eq $Inc 2>/dev/null ]; then
    IncAbsVal=`bc <<< "$Current+$Inc*$Max/100"`
    sudo bash -c "echo $IncAbsVal >> $BrightnessFile"
    exit
elif [ -n "$Dec" -a $Dec -eq $Dec 2>/dev/null ]; then
    DecAbsVal=`bc <<< "$Current-$Dec*$Max/100"`
    sudo bash -c "echo $DecAbsVal >> $BrightnessFile"
    exit 0
elif [ -n "$Set" -a $Set -eq $Set 2>/dev/null ]; then
    SetAbsVal=`bc <<< "$Set*$Max/100"`
    sudo bash -c "echo $SetAbsVal >> $BrightnessFile"
    exit 0
else
    usage
fi
Adobe
  • 3,971
