Software Updates is capable of checking for updates and installing them without asking for a password except for kernel updates.
The same is not true for apt-get in a terminal. If you try to apt-get update without sudo you get an error: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied).
Is there a command you could run in terminal which permits updating without using sudo?
Raja G
  • 105,327
  • 107
  • 262
  • 331
To Do
  • 15,833
Software Updates uses aptdaemon to do all the work. You can do that from the command line using aptdcon:
Check for updates:
aptdcon --refresh
Install updates:
aptdcon --safe-upgrade
open your sudoers file as sudo nano /etc/sudoers from your terminal and
Then do as
<your-username> ALL=NOPASSWD: sudo apt-get update
save & close.
Then check & If its asking same restart your PC and try again.
hope that helps.
Raja G
  • 105,327
  • 107
  • 262
  • 331
