I've got an Asus EEE PC 1005HAB, and after upgrading to 11.04 I can no longer use Fn+F7 to turn on/off the screen backlight. The other Fn+FX keys I've tried so far all work. Is there some standard fix, or should I report this? A quick Google search didn't turn up anything.
I used a Eee PC 1005HA to confirm this. Running dmesg I get:
keyboard: can't emulate rawmode for keycode 244
The keycode refers to XF86KbdLightOnOff, so I think this is a bug.
Workaround:
- Use
xrandr -qto get the monitor's name, should be something like LVDS1. - Use compizconfig-settings-manager
commands plugin to set hotkeys to:
xrandr --output LVDS1 --offchange LVDS1 with your monitors name.xrandr --autodont use output with this command, it seems to cause window glitches.
- 2,962
There's an alternative to turn off the backlight of the LCD whenever you want. Just type
xset dpms force off
and press enter in a terminal, or make a desktop launcher of it and attach it in the unity panel.
If you're using gnome shell then there's a gnome shell extension to attach a desktop launcher to the top panel, then with a single click u can turnoff your lcd.
If it works you can also make a keyboard shortcut for xset dpms force off
- 72,312
- 1,377
An upgrade from 10.10 to 11.04 removed several packages from me. One of them was smartdimmer. It's package description is:
Nvidia Geforce 6200Go, Geforce 8, Geforce 9, and other cards contain hardware LCD brightness control. Smartdimmer allows this to be controlled through software.
Try installing it, I do not guarantee anything though.
The logs of the upgrade process can be found in /var/log/dist-upgrade, and the log for installed / removed packages in /var/log/dist-upgrade/history.log.
- 178,446
I have made a Unity launcher to turnoff the LCD. You can also try this
sudo apt-get install --no-install-recommends gnome-panel
gnome-desktop-item-edit ~/Desktop/ --create-new
it will open a small window
- in name type :
turnofflcd - in command type :
xset dpms force off
I read about making a launcher here on Ubuntu Geek
- 72,312
- 1,377
