10
My battery died on an upgrade and now I have this problem when I try to install updates. How do I fix it?
linux-generic: Depends: linux-image-generic (= 3.2.0.52.62) but 3.2.0.57.68 is installed
Depends: linux-headers-generic (= 3.2.0.52.62) but 3.2.0.57.68 is installed
Avinash Raj
  • 80,446
user224338
  • 101
Fire this at command line:
 $ sudo apt-get install -f
This checks your lib and if it finds unmet dependency, it'll fetch the needed files and install them.
Meanwhile - that dependency version of image-generic told me that you are running on 12.04. Perhaps this case will do the trick:
    $ sudo apt-get install syslinux-themes-debian-wheezy
    $ sudo apt-get upgrade && sudo apt-get dist-upgrade
    $ sudo dpkg-reconfigure -a
Faron
  • 1,418
  • 14
12
I just ran into this unmet dependencies problem while trying to do an "apt-get upgrade", but also had the additional issue of /boot having run out of space.
Some errors which provide clues that your /boot is out of space:
gzip: stdout: No space left on device
No apport report written because the error message indicates a disk full error
This meant that apt-get was helpless, with "sudo apt-get install -f" and "sudo apt-get autoremove" failing to work.
In the end, the link in Justin's answer provided the solution:
1) Check how many old linux-generic kernels you've got installed:
find /boot -type f -regex "^.*-generic"
2) If more than 2, manually clean out the old ones
sudo find /boot -type f -regex "^.*XX-generic" -delete
Replacing XX with the number of the old kernel you wish to remove (e.g. find /boot -type f -regex "^.*24-generic" -delete) Make sure you leave the latest two kernels (highest two numbers).
3) Now you've got space to fix the unmet dependencies:
sudo apt-get -f install
michaeljtbrooks
  • 186
Removing and reinstalling linux-generic will solve this issue.To do this,try the below command on virtual console(ctrl+alt+F1)
sudo apt-get purge linux-generic
sudo apt-get install --reinstall linux-generic
Avinash Raj
  • 80,446
I know this is a fairly old thread, but found a solution on another forum. The person suggested deleting all of the old kernel files as I ran into the same problem. It was because my /boot partition was full and therefore apt couldn't unpack and install anything. Here it is: How to handle out of space errors
Cheers, Justin
Justin
  • 41
