I'm using Ubuntu installed inside windows with Wubi.
During upgrade to 12.04 I came across a rather devious trap. About 25% through the installation of packages, I get the message that packages can't be installed due to lack of disk space on /usr. And of course, its down to 140M when I check.
So what to do? Can't interrupt, can't continue. Since I have a huge disk that seems accessible, which is /host, namely the USB HDD I have Ubuntu installed on, I figure what the heck, perhaps I can copy over some files there and then make links to them in /usr. So I tried sudo mv /usr/lib /host/usr, but all this did was cause error messages and leave the files in place, while creating copies in /host/usr, a behaviour I found oddly disconcerting: What happened? Did some files get moved and some not?
So I figured, perhaps I can check and see if I can remove some stuff with apt-get, but that gave the error that there was a lock on the dpkg something or other, "perhaps it is used by another process?".
What's left to do? I clicked through the warnings of packages not being installed and rebooted, and now startup is aborted and I end up at the text-only login prompt.
So, my installation is screwed, I'll probably just reinstall and do it without Wubi this time.
My question is two-fold:
  1. Why wouldn't an installation process check disk space required before I click ok? Especially when it cannot be interrupted.
  2. Is there a way to get around these kind of traps, where you need space now. What tricks are there?
TLP
  • 3,341
Upgrade manager running out of space
As mentioned in comment, this is a bug. This isn't supposed to happen. Make sure you have 3GB or more before running the upgrade.
Freeing up space while the upgrade is running
You can't use apt-get since the update-manager is already holding the package locks. You also can't manually delete the package cache since it's probably got all the packages in it you've just downloaded.
All you can do is move personal data and manually delete non-essential files:
  1. Move personal data from Documents, Pictures etc. to /host
  2. Delete large files in Downloads e.g. ISOs
  3. Clear your browser cache manually e.g. ~/.mozilla/firefox/Cache or ~/cache/google-chrome/Default/Cache. This can free up 1GB sometimes.
  4. Manually remove older kernels by looking in /boot and deleting all but the latest vmlinuz-..., initrd.img-..., System.map-..., abi-... and config-... (this can free up a couple of hundred MB if you have a lot of old kernels).
  5. Use the disk usage analyzer to look for large logfiles or hidden data that you can delete or move.
I still think this is simply a bug that must be fixed, rather than trying to find a solution. Running around deleting or moving data isn't a really great solution (and obviously carries some risk if you accidentally remove something essential or of personal value.
bcbc
  • 6,036
