I have a Samsung netbook N150Plus (mod# NP-N150-JP02UK) on which I have just installed 11.04 but although the function key works for the screen brightness and brings up the brightness +/- animation, it does not actually change the brightness.
With power on, the screen is bright but at least I can see it (but not change it) but on battery power, the screen is so dim its almost unusable in normal daylight. I have made changes to power management to no avail. Also had the same issue when I had 10.10 installed before upgrading.
Is this a driver issue of a Linux setting problem? Any help appreciated.
Jorge Castro
  • 73,717
Andy T
With installing the Voria-Tools we can overcome limitations of a standard Ubuntu installation on Samsung netbooks. Just add the following ppa to your sources:
ppa:voria/ppa
and install samsung-backlight from there. You may also find other interesting tools ther to control your Samsung netbook.
In case the functions still do not work properly I suggest you contact the Voria team to help them solve the problem.
Takkat
  • 144,580
