How can I set a custom value for font DPI in KDE?
The only options available in KDE are 96 and 120 DPI values. My Screen resolution is 1920*1080, so I would like to keep the DPI at a value higher than 120.
I know how to do this in gnome. Could any one tell how to set custom DPI values in KDE?
A GUI method is preferred
AIB
  • 1,441
Just go to System Settings > Application Appearance > Fonts, and manually enter the dpi value you would like. No need to change fonts.conf.
Incidentally, most desktop environments have a GUI way to change this. Even lightweights like XFCE have it.
Seth
  • 59,332
Configuration can be done per-user through ~/.fonts.conf, and globally with /etc/fonts/local.conf. The settings in the per-user configuration have precedence over the global configuration. Both these files use the same syntax.
Just scroll down and change the DPI value in the conf file. You may have to restart x or logout/login to KDE to get the change to apply.
This applies to most DEs, I don't know of any GUI method to do it other than what you have tried already.
font config man page!
dekyos
  • 121
