42
I am trying to run Chamsys MagicQ on Ubuntu 12.10 with 64bit AMD processor.
This is what it tells me when I try to run the program.
./magicq: error while loading shared libraries: libGLU.so.1: cannot open shared object >file: No such file or directory
Here is the list of library dependencies for MagicQ:
austin@ubuntu:~/magicq$ ldd ./magicq
linux-gate.so.1 => (0xf7799000)
libGLU.so.1 => not found
libusb-0.1.so.4 => not found
libQt5PrintSupport.so.5 => not found
libQt5OpenGL.so.5 => not found
libQt5Widgets.so.5 => not found
libQt5Network.so.5 => not found
libQt5Gui.so.5 => not found
libQt5Core.so.5 => not found
libGL.so.1 => /usr/lib32/fglrx/libGL.so.1 (0xf7694000)
libpthread.so.0 => /lib/i386-linux-gnu/libpthread.so.0 (0xf7679000)
libstdc++.so.6 => not found
libm.so.6 => /lib/i386-linux-gnu/libm.so.6 (0xf764d000)
libgcc_s.so.1 => /lib/i386-linux-gnu/libgcc_s.so.1 (0xf762e000)
libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xf7483000)
libXext.so.6 => not found
libatiuki.so.1 => /usr/lib32/fglrx/libatiuki.so.1 (0xf746c000)
libdl.so.2 => /lib/i386-linux-gnu/libdl.so.2 (0xf7467000)
/lib/ld-linux.so.2 (0xf779a000)
I know libGLU.so.1 is in /usr/lib/x86_64-linux-gnu as a "link to shared library (application/x-sharedlib)" Link target: "libGLU.so.1.3.1" How do I fix this?
Austin
  • 651
7 Answers7
49
Actually I couldn't find libglu package itself. What helped is:
sudo apt-get install libglu1-mesa:i386
Ubuntu 14.04 x64
Daniel
  • 788
22
I just needed to install this, without any 32-bit or 64-bit reference.
egreene
  • 329
13
I figured it out. I had to install the 32-bit versions.
For anyone else who may have the same problem and is running a 64-bit operating system. Find the packages that include the missing files and use:
sudo apt-get install package:i386
Change "package" to the name of the package. Without the ":i386" it will install the 64 bit version only.
Austin
  • 651
In case anyone is reading this using Ubuntu 18.04, here's one way to search for the package to install. I got this error when trying to run Blender on a new Ubuntu 18.04 machine from a cloud computing instance. Here was the error, where I try to check if Blender 2.82a is installed correctly by printing out the version:
user@init-blender-test:~/blender-2.82a-linux64$ ./blender --version
./blender: error while loading shared libraries: libGL.so.1: cannot open shared object file: No such file or directory
To find the package to install, I did an apt-file search:
user@init-blender-test:~/blender-2.82a-linux64$ apt-file search libGL.so.1
libgl1: /usr/lib/x86_64-linux-gnu/libGL.so.1
libgl1: /usr/lib/x86_64-linux-gnu/libGL.so.1.0.0
nvidia-340: /usr/lib/i386-linux-gnu/libGL.so.1
nvidia-340: /usr/lib/x86_64-linux-gnu/libGL.so.1
primus-libs: /usr/lib/x86_64-linux-gnu/primus/libGL.so.1
virtualbox-guest-x11: /usr/lib/virtualbox/additions/libGL.so.1
virtualbox-guest-x11-hwe: /usr/lib/virtualbox/additions/libGL.so.1
See this StackOverflow answer for more details. If apt-file isn't found, you may need to install it with sudo apt install apt-file.
Therefore, from the above, I see that sudo apt install libgl1 can be used, and it fixed my error. Note that there are multiple packages that reference the missing file (nvidia-340, etc.) so you'll have to judge and test for yourself on a case-by-case basis.
This would help
sudo apt-get install libgl1-mesa-dri:i386 libglapi-mesa:i386  libglx-mesa0:i386  libglx0:i386  libgl1:i386 libgl1-mesa-glx:i386 libglu1-mesa:i386
ChauhanTs
  • 121
i needed libGLU.so.1 for a game i wanted to play (The Fall) and got this error:
after a search i found a bug page where someone mentioned ia32-libs, and after installing that im up and runnig.
page i found:
https://bugs.launchpad.net/linuxmint/+bug/891578
Command i ran:
sudo apt-get install ia32-libs
Tcuc
  • 31
I had same kind of problem when i had deleted some of the files, i got them back using this command
sudo apt-get install libglew-dev libcheese7 libcheese-gtk23 libclutter-gst-2.0-0 libcogl15 libclutter-gtk-1.0-0 libclutter-1.0-0
Hope it would work.
