The specific error you're getting is because of the way you are trying to execute the script (and the rather strange way the script is written).
When a script is run, positional parameter 0 contains the name by which the script was invoked, e.g. path/to/start.sh - or simply ./start.sh if it is called from the current directory. The parameter expansion syntax ${0%/*} removes the shortest suffix from $0 matching /* leaving (respectively) path/to or just . and the script then attempts to change to this directory - in other words, to the parent directory of start.sh
However, when you use sh start.sh (as well as executing the script using sh instead of the intended /bin/bash), $0 equals start.sh. Since there's no matching /, ${0%/*} doesn't remove anything from $0, resulting in the script trying to execute the command cd start.sh which obviously fails because start.sh is a file not a directory.
The solution is to execute the script the way the author presumably intended - that is, by ensuring it is executable
chmod +x start.sh
and then executing it directly, e.g.
./start.sh
