I have a virtualbox running ubuntu 13.10 (running on a 13.10 host) that has two shared folders on the host that are mounted at boot. A while ago the guest ran some updates that broke the folder sharing, the guest could no longer see the devices to mount them. I had a hunch from reading around that it might be something to do with the guest additions, as getting the 4.3 release of virtualbox from the oracle repo and updating the guest additions solved the problem. The issue is, today's linux headers update broke the mount again, and there doesn't appear to be an updated guest additions to go to! (re-installing them doesn't work).
Obviously at a basic level, not installing the updates would prevent this problem. However I'd be interested in finding out exactly why it's behaving like this.
I'm a bit out of my depth here but if someone could point me in the right direction of a solution I'd appreciate it.
If there's more useful info I can provide let me know.
Full error message I'm now getting when trying to use the manager to mount the Guest Additions CD Image:
Unable to access "VBOXADDITIONS_4.3.4_91027"
Error mounting /dev/sr0 at /media/ptinkler/VBOXADDITIONS_4.3.4_91027: Command-line 'mount -t "iso9660" -o "uheper=udisks2,nodev,nosuid,uid=100,gid=1000,iocharset=utf8,mode=0400,dmode=0500" "/dev/sr0" "/media/maplecroft/VBOXADDITIONS_4.3.4_91027" exited with non-zero exit stats 32: mount: unknown filesystem type 'iso9660'
ptr
  • 143
Virtual Box shared folders functionality depends on guest additions kernel modules. A kernel update should automatically reload all modules using dkms (which should be installed by default).
Unfortunately this does not always work as expected. Then we have to reinstall the guest additions:
Guest additions will then be available after a reboot of the guest.
If this fails it is worth to try again as sometimes the installation does not work as expected (without errors or warnings).
It may also worth to try to remove the guest additions before we install them again using the uninstall script (replace x.x.xxx with your version of Virtual Box):
cd /opt/<VirtualBoxAddtions-x.x.xx>/
sudo ./uninstall.sh
Takkat
  • 144,580
This worked! My internet was working from guest OS. So I could download the additions ISO and extract. Also was able to install it easily
I also had taken two steps before this (not sure if they helped, but they shouldnt hurt since the steps downloaded all headers and prepped kernel for guest adds)
Steps:
sudo apt-get install build-essential module-assistant
sudo m-a prepare
muru
  • 207,228
-1
Open Ubuntu in VirtualBox. Open FireFox and go here.
Find your version of Virtualbox and click the link to open it.
Download your version of VBoxGuestAdditions (iso):
Open it in Archive manager and extract files
run:
sudo VBoxLinuxAdditions.run
Reboot.
Eric Carvalho
  • 55,453
