I can hear the sound from my laptop speakers on the startup but after that when I try to play any music on VLC I don't hear any sound. I can't even hear any sound on youtube so it's not the problem with VLC. If I try running any sound by Guest user then it works.
Asked
Active
Viewed 1.6k times
Triedalsamixer in terminal? Remove all of the M's by using the cursor keys to navigate below an output labeled as MM and tap M to unmute it. The cursor up and down keys can also be used to adjust the volume if necessary.
For more possible answer's, see here: No Sound in Ubuntu 12.04
Elder Geek
- 36,752
Wilf
- 30,732
If nothing works,reinstall the audio system. Run the following code:
sudo apt-get remove --purge alsa-base pulseaudio
sudo apt-get install alsa-base pulseaudio
sudo alsa force-reload
Hope that helps. !
ASCIIbetical
- 897
