Not able to install any software from ubuntu software center. There is no response after pressing install button.
The error which I get
Traceback (most recent call last):
File "/usr/lib/python2.7/dist-packages/defer/init.py", line 475, in _inline_callbacks result = gen.send(result)
File "/usr/lib/python2.7/dist-packages/aptdaemon/client.py", line 1622, in
_run_transaction_helper
daemon = get_aptdaemon(self.bus)
File "/usr/lib/python2.7/dist-packages/aptdaemon/client.py", line 1696, in get_aptdaemon False),
File "/usr/lib/python2.7/dist-packages/dbus/bus.py", line 241, in get_object follow_name_owner_changes=follow_name_owner_changes)
File "/usr/lib/python2.7/dist-packages/dbus/proxies.py", line 248, in init self._named_service = conn.activate_name_owner(bus_name)
File "/usr/lib/python2.7/dist-packages/dbus/bus.py", line 180, in activate_name_owner self.start_service_by_name(bus_name)
File "/usr/lib/python2.7/dist-packages/dbus/bus.py", line 278, in
start_service_by_name 'su', (bus_name, flags)))
File "/usr/lib/python2.7/dist-packages/dbus/connection.py", line 651, in call_blocking message, timeout) dbus.exceptions.DBusException: org.freedesktop.DBus.Error.Spawn.ChildExited: Launch helper exited with unknown return code 1 Traceback (most recent call last): File "/usr/lib/python2.7/dist-packages/defer/init.py", line 475, in _inline_callbacks result = gen.send(result) File "/usr/lib/python2.7/dist-packages/aptdaemon/client.py", line 1622, in _run_transaction_helper daemon = get_aptdaemon(self.bus) File "/usr/lib/python2.7/dist-packages/aptdaemon/client.py", line 1696, in get_aptdaemon False), File "/usr/lib/python2.7/dist-packages/dbus/bus.py", line 241, in get_object follow_name_owner_changes=follow_name_owner_changes)
File "/usr/lib/python2.7/dist-packages/dbus/bus.py", line 278, in start_service_by_name 'su', (bus_name, flags)))
Edit 1
New errors after running the command given in the answer.
I tried with sudo too.
A part of the error code
Removing /usr/local/lib/python2.7/dist-packages/setuptools-1.4.1-py2.7.egg Copying setuptools-1.4.1-py2.7.egg to /usr/local/lib/python2.7/dist-packages setuptools 1.4.1 is already the active version in easy-install.pth Installing easy_install script to /usr/local/bin error: /usr/local/bin/easy_install: Permission denied Something went wrong during the installation. See the error message above.
Sai
  • 43
permissions in your python packages are possibly not working , change its permission by using-
sudo chown -R $USER /usr/local/lib/python2.7/dist-packages/
-Replace USER with your login name, if this doesnt works check the output of -
/usr/lib/ubuntu-sso-client/ubuntu-sso-login
If it throw any error ImportError: No module named pkg_resources
then the reason behind this could be setup tools package has been deleted in my Python environment .to solve this use the following script-
curl https://bitbucket.org/pypa/setuptools/raw/bootstrap/ez_setup.py | python
hope it will work.
Sukupa91
  • 3,067
