13
I have a external seagate 1TB USB hard disk. Every time I connect it to my computer it gets automatically mounted. While removing it I select safely remove option rather than unmount because I read somewhere that it is recommended.
I have two questions:-
  1. Is true that just unmounting can damage my hard disk. Should I always select safely remove option? (I know the difference between unmount and safely remove and I have also noted that unmounting removes it from file table entry but safely removing actually stops using it. The power supply LED goes off after safely removing which doesn't happen with unmount).
  2. The first question leads me to this! How do I `safely remove my hard disk from command line?
(I know how to umount it.. but even if I unmount it it is still shown in fdiks -l I don't want that)
user.dz
  • 49,176
Null pointer
  • 2,607
5 Answers5
10
Try this. Just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command(s) below:
sudo umount /dev/<device_id>
addition/correction (if you want to go by device uuid, i.e. not something like "sda3" but rather its unique long numeric/hex string like "366A52F225612...") use
sudo umount /dev/disk/by-uuid/<device_id>
Or you can use udisks.
sudo udisksctl unmount /dev/<device_id>
You can get the device ID using sudo fdisk -l command
To install udisks if not installed, just do
sudo apt-get install udisks
For more info see the udisks manpage
Frank N
  • 1,430
Mitch
  • 109,787
Ubuntu comes with Udisks daemon, which allows mounting/unmounting , and doing several other things with block devices (aka drives) without need for sudo as in the case of mount commands. Of particular interest is the options for detaching/powering-off the drive.
For newer releases, use udisksctl command, specifically this sequence:
udisksctl unmount -b /dev/sdc1 && udisksctl power-off -b /dev/sdc
Older versions of Ubuntu (13.10 and earlier) can use the following
udisks --unmount /dev/sdb1 && udisks --detach /dev/sdb
In both commands the idea is the same: the command both unmounts and then powers-down the device(if your USB device has LED, no LED will be flashing and it won't show up in udisksctl status or df).
For convenience, both of these commands could be made a function in ~/.bashrc , for instance:
drive_off(){
    # Function that unmounts and powers off a USB drive
    # Usage example: drive_off /dev/sdc1
    device=$(awk '{print substr($0,0,length($0)-1)}' <<< "$1")
    udisksctl unmount -b "$1" && udisksctl power-off -b "$device"
Reference: ubuntuforums.org
Also, refer to udisks manual page through terminal for more info: man udisks
  1. Unmounting won't damage your disk or data. Unplugging it while it is still in use can corrupt the data. Unmounting it will generally also sync the filesystem which makes it safe to eject the disk. Check the led for activity. If you want to be totaly sure there is the command sync which, according to the man page, forces changed blocks to disk and updates the super block.
  2. Apparently its not safe for some devices to unplug them when they are on. So the to be absolutely safe some file managers give the option to remove the device from the system entirely.
cccplex
  • 466
Run this command to get your device path:
lsblk
A command to unmount a drive would be:
udisksctl unmount -b /dev/$DEVICE
kiri
  • 28,986
These also work (14.04):
$ udisks --mount  /dev/sdi1
$ udisks --unmount  /dev/sdi1
NOTED: no need to 'sudo' and both of
$ udisks --unmount
$ udisksctl unmount
leaves the LED lit on my Sandisk Imagemate (USB3.0 card reader).
Other ways to find out devices
blkid -o list
ls -lR /dev/disk/
Hannu
  • 6,605
  • 28
  • 45
