I have an external usb hard drive, however when I try to safely remove it, the device turns off and then the device mounts itself again. I've tried to do
sudo udisks --detach /dev/sdb
However, the device gets mounted again!
Any solutions? Thanks for reading :)
For removing your device, you should un-mount it:
sudo umount /dev/sdb
in case it failed to un-mount, you should force it by add -f option:
sudo umount -f /dev/sdb
