This is my first post. I wanted to ask for any idea so to solve my problem. I am using Ubuntu 12.04 LTS, and my purpose is to use OpenFoam CFD software.
I am trying to execute an script called Allrun that corresponds to a tutorial. I am using the sudo command like this.
sudo ./Allrun
then it asks for my password and after introducing it, it suddenly appears a message saying:
./Allrun: 5: .: Can't open /bin/tools/RunFunctions
This path appeares at line 5 as sourced in the script, so like:
. $WM_PROJECT_DIR/bin/tools/RunFunctions
being $WM_PROJECT_DIR a variable defined in opt/openfoam22/etc/bashrc and pointing the directory:
$WM_PROJECT_DIR= /opt/openfoam222
(this bashrc is at the same time sourced in ~/.bashrc file, and I can use the variable in the terminal, so I assume it is allright sourced)
I have tried also to chmod the RunFunctions file with rwx permissions, and veryfied with "ls -la" that its permissions changed (they did), but didn't solve anything.
I am new in linux, and any help will be great, thanks in advance.
Danubi
  • 33
It seems that at the point of execution, the variable is not defined; the script search for a file /bin/tools/RunFunctions/, not /opt/openfoam222/bin/tools/RunFunctions.
Notice that non-interactive shells does not load .bashrc by default, so the fact that the variable is defined when you use it in interactive is not a proof. Even if you are running the script from you shell, the variables are not exported to sub-shell by default, they need to be declared export to do that.
Try to add a line like
echo "DEBUG variable is $WM_PROJECT_DIR"
before the failing line in ./Allrun and check the output. If this is the problem, you should explicitly source the file in your script. Or add an
export WM_PROJECT_DIR
to pass it to subshells.
Added (after comments). Notice that you shouldn't explicitly source your .bashrc in your .profile (they have different meaning and the shell sources them in different occasions, see for example here.)
Scripts (non-interactive) should never rely on your login shell to run. If they need specific files/definitions, the should source them explicitly. For what you know, it could be called even from a different type of shell or from no shell at all.
Rmano
  • 32,167
