257
Problem
I have an Ubuntu 11.04 Virtual Machine and I wanted to set up my Java development environment. I did as follows
  1. sudo apt-get install openjdk-6-jdk
  2. Added the following entries to ~/.bash_profile
    export JAVA_HOME=/usr/lib/jvm/java-6-openjdk
    export PATH=$PATH:$JAVA_HOME/bin
  3. Save the changes and exit
  4. Open up a terminal again and typed the following
    echo $JAVA_HOME   (blank)
    echo $PATH        (displayed, but not the JAVA_HOME value)
  5. Nothing happened, like if the export of JAVA_HOME and it's addition to the PATH were never done.
Solution
I had to go to ~/.bashrc and add the following entry towards the end of file
#Source bash_profile to set JAVA_HOME and add it to the PATH because for some reason is not being picked up
. ~/.bash_profile
Questions
  1. Why did I have to do that? I thought bash_profile, bash_login or profile in absence of those two get executed first before bashrc.
  2. Was in this case my terminal a non-login shell?
  3. If so, why when doing su after the terminal and putting the password it did not execute profile where I had also set the exports mentioned above?
Jorge Castro
  • 73,717
Viriato
  • 2,781
  • 16
7 Answers7
311
~/.bash_profile is only sourced by bash when started in login mode. That is typically when you log in at the console (Ctrl+Alt+F1..F6), connect via ssh, or use sudo -i or su - to run commands as another user.
When you log in graphically, ~/.profile will be specifically sourced by the script that launches gnome-session (or whichever desktop environment you're using). So ~/.bash_profile is not sourced at all when you log in graphically.
When you open a terminal, the terminal starts bash in (non-login) interactive mode, which means it will source ~/.bashrc.
The right place for you to put these environment variables is in ~/.profile, and the effect should be apparent next time you log in.
Sourcing ~/.bash_profile from ~/.bashrc is the wrong solution. It's supposed to be the other way around; ~/.bash_profile should source ~/.bashrc.
See DotFiles for a more thorough explanation, including some history of why it is like it is.
(On a side note, when installing openjdk via apt, symlinks should be set up by the package, so that you don't really need to set JAVA_HOME or change PATH)
geirha
  • 47,279
69
You can check if your Bash shell is started as a login-shell by running:
shopt login_shell
If the reply is off you are not running a login shell.
Read the Bash manual's invocation section on how Bash reads (or does not read) different configuration files.
Excerpt from man bash:
When bash is invoked as an interactive login shell, or as a non-interactive shell with the --login option, it first reads and executes commands from the file /etc/profile, if that file exists. After reading that file, it looks for ~/.bash_profile, ~/.bash_login, and ~/.profile, in that order, and reads and executes commands from the first one that exists and is readable.
su on the other hand also does not start a login shell by default, you have to tell it to do so by using the --login option.
lgarzo
  • 20,492
44
I think it is worth mentioning that you can change the default of gnome-terminal to use a login shell (ie. bash -l) by editing the profile preferences.
go to Edit -> Profile Preferences -> Title and Command tab check the "Run command as a login shell" option
kisoku
  • 551
18
If you open a terminal or run su the shell is not executed as a login shell but as a normal interactive shell. So it reads ~/.bashrc but not ~/.bash_profile. You can run su with the -l option to make it run your shell as a login shell.
When you are working with a GUI the shell is usually never run as a login shell so it's usually fine to put all yout stuff in ~/.bashrc.
15
TL;DR
In classical recommended ubuntu setup, ~/.bash_profile gets evaluated only in specific occasions. And it makes sense.
Put your stuff in ~/.bashrc, it'll get evaluated everytime.
Ok, I want to understand, why does this make sense ?
Keypoints to understand what is going on:
  • all processes on linux have and uses environment variables
  • environment variables are inherited
  • thus setting them once on the father of all your process is enough (especially if it requires some computation time.)
  • the father of all your process is typically launched after you log in on your device (give your credentials).
  • there are things you might want to do only once when you log in on your computer (check for new mail for instance...).
So "login" time is typically:
  • In console mode, when you login (with Ctrl-Alt F1) or through ssh, as the shell will be the father of all process, it'll load your ~/.bash_profile.
  • In graphic mode, when you open your session, the first process (gnome-session for classical ubuntu) will be in charge to read
    .profile.
Ok, so where to put my stuff ?
It's rather complex, the full story is here. But here is a run down that is pretty common for ubuntu users. So considering that:
  • you use bash shell,
  • you have a ~/.bash_profile and follow the recommendation to add the loading of ~/.bashrc in your ~/.bash_profile so as to get at least one file that gets evaluated whatever is the invocation mecanism.
This is a quick suggestion of where to put things.
  • ~/.bashrc (Gets evaluated in all occasion, provided you follow the recommendation)
    For fast-evaluation environment variable and code for your user-only and bash-only command-line usage (aliases for instance). bashism are welcome.
    It gets loaded on itself upon:
    • make a new shell window/pane in graphical sessions.
    • calling bash
    • screen new pane or tab. (not tmux !)
    • any bash instance in a graphical console client (terminator/gnome-terminal...) if you don't tick option "run command as login shell".
    And it will get loaded in all the other occasion thanks to the prior recommendation.
  • ~/.bash_profile (Gets evaluated in specific occasion only)
    For slow-evaluation environment variable and code for your user-only and console-session processes. bashism are welcome. It gets loaded on:
    • console login (Ctrl-Alt F1),
    • ssh logins to this machine,
    • tmux new pane or windows (default settings), (not screen !)
    • explicit calls of bash -l,
    • any bash instance in a graphical console client (terminator/gnome-terminal...) only if you tick option "run command as login shell".
  • ~/.profile (Gets evaluated only in graphical-session)
    For slow-evaluation environment variables and with no-bashism for your user-only and all graphical-session processes. It gets loaded upon login in your graphical UI.
vaab
  • 1,112
When you do sudo su the shell is not executed, instead of that try with sudo su - this will load ~/.bash_profile as source by default.
They want you to put it in ~/.bash_aliases now
in ~/.bashrc there is this code pointing it out:
# Alias definitions.
# You may want to put all your additions into a separate file like
# ~/.bash_aliases, instead of adding them here directly.
# See /usr/share/doc/bash-doc/examples in the bash-doc package.
if [ -f ~/.bash_aliases ]; then . ~/.bash_aliases fi
