Bash Arithmetic
Another possible solution is to add a simple function for Bash's built-in arithmetic. Put this in your .bashrc file to try it out:
echo "$(($@))"
So now, you don't even need $((...)) anymore, just = which seems natural enough.
Replacement
Another thing if you want to be even faster: you can make it replace p with + and x with *. This will work for that:
local IFS=' '
local calc="${*//p/+}"
calc="${calc//x/*}"
echo "$(($calc))"
= 5 x 5 # Returns 25
= 50p25 # Returns 75
Now you don't even need Shift anymore, the only thing is = in front of arithmetic.
Hexadecimal output
Output can be displayed in both decimal and hexadecimal, if so desired. (Note: using x substitution will conflict with the 0x... hex syntax)
local answer="$(($@))"
printf '%d (%#x)\n' "$answer" "$answer"
Example:
$ = 16 + 0x10
272 (0x110)
$ = 163 + 164
69632 (0x11000)
Using bc
If you want slightly more advanced calculations, you can pipe it to bc like so:
local IFS=' '
calc="${calc//x/*}"
bc -l <<<"scale=10;$calc"
= 'sqrt(2)' # Returns 1.4142135623
= '4*a(1)' # Returns pi (3.1415926532)
The functions provided by bc are as follows (and can be found in man bc):
sqrt ( expression )
The value of the sqrt function is the square root of the expression.
If the expression is negative, a run time error is generated.
s (x) The sine of x, x is in radians.
c (x) The cosine of x, x is in radians.
a (x) The arctangent of x, arctangent returns radians.
l (x) The natural logarithm of x.
e (x) The exponential function of raising e to the value x.
j (n,x)
The Bessel function of integer order n of x.
It also supports if, for, while, and variables like a programming language. Though it may be better to write to a file if you wanted that.
Keep in mind that it will substitute p and x in function/variable names. It may be better to just remove the replacements.
Using gcalccmd
You can also make the function call gcalccmd (from gnome-calculator) like so:
local IFS=' '
local calc="$*"
# Uncomment the below for (p → +) and (x → *)
#calc="${calc//p/+}"
#calc="${calc//x/*}"
printf '%s\n quit' "$calc" | gcalccmd | sed 's:^> ::g'
= '4^4' # Returns 256
The available functions seem to be (taken straight from the source code), == denotes equivalent functions:
ln()
sqrt()
abs()
int()
frac()
sin()
cos()
tan()
sin⁻¹() == asin()
cos⁻¹() == acos()
tan⁻¹() == atan()
sinh()
cosh()
tanh()
sinh⁻¹() == asinh()
cosh⁻¹() == acosh()
tanh⁻¹() == atanh()
ones()
twos()
