How can I install libqtwebkit5 library?
I need it for a Qt project. I tried with:
$ sudo apt-get install libqtwebkit5
Reading package lists... Done
Building dependency tree
E: Unable to locate package libqtwebkit5
I have this problem on both: 12.04 and 13.10
Braiam
  • 69,112
Ionică Bizău
  • 9,803
  • 25
  • 89
  • 129
Your package name has a missing 5, its name is libqt5webkit5 not libqtwebkit5:
sudo apt-get install libqt5webkit5
The following packages were automatically installed and are no longer required:
  xaw3dg xfig-libs
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
  libqt53d5 libqt5core5 libqt5dbus5 libqt5gui5 libqt5location5 libqt5network5
  libqt5opengl5 libqt5printsupport5 libqt5qml5 libqt5quick5 libqt5sensors5
  libqt5sql5 libqt5sql5-sqlite libqt5v8-5 libqt5widgets5 libxcb-icccm4
  libxcb-image0 libxcb-keysyms1 libxcb-randr0 libxcb-render-util0 libxcb-sync0
The following NEW packages will be installed:
  libqt5sql5 libqt5sql5-sqlite libqt5v8-5 libqt5webkit5 libqt5widgets5
  libxcb-icccm4 libxcb-image0 libxcb-keysyms1 libxcb-randr0
0 upgraded, 22 newly installed, 0 to remove and 0 not upgraded.
Need to get 18.4 MB of archives.
After this operation, 71.5 MB of additional disk space will be used.
Do you want to continue [Y/n]?
Braiam
  • 69,112
Reason islibqtwebkit5 isn't in Ubuntu Official Repository. only libqtwebkit4 is available. But there is libqt5webkit5. But it is available only for 13.04 and 13.10.
If you want to have qt5webkit version 5 on 12.04 you can get it from ppa:ubuntu-sdk-team/ppa repository.
To install from it follow this:
sudo add-apt-repository ppa:ubuntu-sdk-team/ppa
sudo apt-get update
sudo apt-get install qtwebkit-opensource-src
