I am having a Sony Vaio SVE1513BYN. I have installed Ubuntu 13.10 . Once I set brightness of my laptop and then after I restart my laptop it is changed. Brightness is going full as default.
Asked
Active
Viewed 447 times
Edit the file /etc/default/grub. You can do this by going to the terminal and typing:
sudo gedit /etc/default/grub
Change the line:
GRUB_CMDLINE_LINUX=""
to
GRUB_CMDLINE_LINUX="quiet splash acpi_osi=Linux acpi_backlight=vendor"
and then save and then run:
sudo update-grub
Then restart the computer, then it should work.
Ranveer
- 285
You could try adding a line to /etc/rc.local that will set the desired brightness level. To edit the file, run
gksudo gedit /etc/rc.local
and add the following
echo X > /sys/class/backlight/intel_backlight/brightness
so that the end result looks like this
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
exit 0
Substitute the X by the desired brightness level.
